Question about HP Compaq Presario 1210, 1210CA, 1210EA, 1210ES, 1210JP, 1210LA, 1210US, 1211, 1211CA, 1211EA, 1211LA, ... (810247013585)
Compaq Presario 1210, hooking it to the internet, what do I need?
My dad has a Pasario 1210 and wants to use his internet connection (dial up) and needs to know what he can do to make this happen, or even if it can be done. I have an idea that he needs to add more memory, and upgrade his windows program.(HE'S RUNNING WINDOWS 95)Hope ypu can help!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 119 Answers
Hello first you change your windows 95. i advise to you windows xp or windows vista is best for internat, games, music, video etc
Posted on Oct 01, 2009
My compaq presario 5240 w/ win 98 wont connect to the internet
make a menu on top toolbar right click in top toolbar
select menu bar this will add file edit view fav tools and help
click on tools then from the drop down list internet options connections tick in never dial a connection
then you will have to add your isp internet service provider
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up usb or
an ethernet connection to connect to the internet or
if you have a laptop you can choose a wireless usb modem
which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
hope it helps
Jun 18, 2012 | Compaq Presario 5240 (353200-003) PC...
I have a dell desktop with wireless connection, there is also a wireless router connected to the dell to send a wireless connection to a laptop in the household. in a bedroom in the house is a compaq...
As you mentioned, your Compaq Presario MV520 is using Windows 98 OS. As we all know, dial-up connection is the only available internet connection at that time so obviously Win 98 has dial-up LAN connection. However, you wanted to have wireless connection on that PC so you need to install a wireless adapter to that PC. First of all, most wireless adapters that are being used for desktop PC are wireless USB adapter, so you need to have a USB port on that PC. And also, you will need to check if the software for the wireless adapter will be accepted by the PC because since the PC is using Win 98 OS, we are not sure if the firmware of the wireless adapter will be compatible to the PC. Basically, my answer would be not possible.
Sep 14, 2011 | Computers & Internet
Can this be hooked up to dial up?
Hi eegnor...
Yes, this can be used with dial up, if you have a modem card installed into the computer, if not, then you can install one very easy and have it hook up to dial-up.
Please take time to rate me
You can see your computer at this site:
http://reviews.cnet.com/desktops/hp-compaq-presario-sr1620nx/1707-3118_7-31589079.html
Aug 28, 2011 | HP Compaq Presario SR1620NX...
I dont have access to internet am missing the hardwere
Most Internet Service providers do provide the modems necessary to connect to the internet. If you are not using a modem and are using dialup, then you will need to make sure your computer has a dial modem and that you have an active phone line to plug into your computer.
If you would like to use DSL or Cable to connect to the internet, then a call to your ISP will be sufficient and a tech will come to hook up your connection.
Nov 15, 2009 | HP Compaq Presario 6320US (DA202A#ABA) PC...
Kicks off dial-up after 5 minutes-dial-up shows still connected compaq presario sr111onx
This is normal. All users of dial up get kicked off randomly to make room on the service providers servers for other users to log on. In addition to it's extremely slow speed, this is the downside to dial up. I would suggest switching to DSL or Cable. It's a constant 'On' connection you cannot get kicked off of.
Apr 25, 2009 | HP Compaq Presario SR1110NX PC Desktop
How do I get internet on my laptop from my pc not using a cable?
what you would need to get is a wirless router. If you have high speed internet then you can plug the internet modem into the wireless router and then plug your main pc into the router via an ethernet cable and then set up your laptop to pick up the signal wirelessly. If you have dial up internet then you would still need a wireless router but it is a little more complicated. You could hook up the router to your main pc and then set up internet connection sharing so that way your laptop could pick it up wirelessly. hopefully this helps.
Apr 10, 2009 | HP Compaq Presario v3000z Notebook
Wireless Internet for compaq Presario
Check out the wireless setup manual for your laptop here:
http://h10032.www1.hp.com/ctg/Manual/c00065819.pdf
Hope this helps!
Mar 28, 2009 | Computers & Internet
Highspeed internet connect vs dial up
Your laptop should have wireless and the best way to check is on either the front/left/right side of the laptop their is a switch that says wireless flick it to the side that says on... If you don't their should be a name above each of the inputs so look for the one that says something like internet/Ethernet or just plug into the ones that fit it and see if you get connected.
Nov 28, 2008 | Compaq Presario 12XL300 (199375-003) PC...
Compaq presario c500..what do i need to buy or purchase to use the internet?
This model has a wireless network adapter built in, so if you are on DSL isp connection you need a wireless DSL modem/router, if cable then a cable router to attach to your cable modem.
Sep 11, 2008 | Compaq Armada 3500 Notebook
HP Compaq Presario 1210, 1210CA, 1210EA, 1210ES, 1210JP, 1210LA, 1210US, 1211, 1211CA, 1211EA, 1211LA, ... (810247013585) Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
