Question about ASUS A7S333 Motherboard
Did crucial memory scan. they recommend 2- 1gb 184-pin unbuff dimm 128mx64 ddrpc2700 installed both sys. did not come up. with 1gb stick at a time sys. comes up fine. but not with both in. please HELP
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Odd. I assume you have tried them in different slot arrangements?
    President:
  • 2,692 Answers
DDR SD ram only. Page 124 of you manual. Dimms with more than 18 pieces are not supported on your board. Seven venders for approved list of RAM chips with model numbers.P15 of you manual.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Jan 18, 2009
COMPATIBLE MEMORY FOR INTEL 2.4 GHZ PROCESSOR
These
two
184-pin DIMM sockets support up to 2GB
system memory using unbuffered non-ECC PC2100
/PC1600
DDR DIMM
Aug 02, 2013 | ASUS P4VP-MX Motherboard
Which RAM to be used in Motherboard D101GGC
1GB 184-pin DIMM
  • Module Size: 1GB
  • Package: 184-pin DIMM
  • Feature: DDR PC2700
This is taken from the Crucial memory configurator for your specific motherboard.
Go to this link for more info.
http://www.crucial.com/store/listparts.aspx?model=D101GGC
Dec 22, 2010 | Intel D101GGC Motherboard
2G RAM's for Elitegroup (ECS) L7VMM2 Rev 1.0A Motherboard
You're board can handel; DDR SDRAM up to 200 or 266MHz DDR SDRAM memory module. Accommodates two "unbuffered", 2.5V 184-pin slots. Each slot supports up to 1 GB with a total maximum capacity of 2 GB. Return the Kingston memory you have installed if it is less than a year old. They should allow you to trade up to the MB's supported memory.
Two reach the MB's max memmory of 2GB. Buy two Kingston DIMMS of, "unbuffered", 2.5V 184-pin
DIMMs. Here is one site that sells Kingston memory;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=235786&CatId=548
The next link is Kingstons site; http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KVR266X64C2/1G
Here is another site; http://www.buy.com/prod/kingston-1gb-ddr-memory-pc2100-266mhz-184-pin-dimm-kingston-1gb-ddr/q/loc/101/10348796.html
If you decide to search for you're self, use this as the basis for the correct model: Module - KVR266X64C2
Link to ECS web site; http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=62&CategoryID=1&MenuID=50&LanID=9
Mike
Jun 02, 2010 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
What is competible RAM for GV 845
''The Desktop Board D845GVSR has two DIMM sockets and supports the following memory features:
  • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered single-sided or double-sided DIMMs
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • DDR333/266/200 MHz SDRAM DIMMs only
  • Serial Presence Detect (SPD)
  • Suspend to RAM
Feb 01, 2010 | Intel D845GVSR Motherboard
What is the maximum memory for this computer?
This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
Oct 27, 2009 | HP Pavilion a620n (PC028A) PC Desktop
I have attempted to upgrade a Gateway GT52223 from 1= Gig existing 2X 512 DIMMS to 2 Gig on two separate occasions first using Using Crucial -2-1GB 240-PIN 128Mx64 DDR2 PC2-6400 UNBUFF CL6 the system...
Your last results is running your comp OK because it is really only running on the 512 stick. When putting 2 different sizes together it will only run on the smallest, with this said here is a website http://www.4allmemory.com it will test your comp to exactly what type RAM you need . I buy for my clients all the time from this website. Very reliable,Try it..and remember about the 2 sizes
Jul 15, 2009 | Gateway GT5220 PC Desktop
Memory problem
The ASUS web site shows only two ram slots on the motherboard. Sounds as if the booklet has a misprint. Specifications on the web site list memory as: Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR SDRAM memory. So, 2GB is max.
Jun 10, 2009 | ASUS P5PE-VM Motherboard
How to install additional 256 MB memory
You simply just push the memory into the DIMM socket on the motherboard. You need to use DDR SDRAM but should check what your I/O bus speed is set at. They make 4 different types of DDR SDRAM. They are DDR-200 (PC1600). DDR-266 (PC2100). DDR-333 (PC2700) and DDR-400 (PC3200). The following links should help you out:
http://www.tech-faq.com/unbuffered-memory.shtml
http://en.wikipedia.org/wiki/DDR_SDRAM
Mar 20, 2009 | EliteGroup P4VMM2 Motherboard
RAM Memory Speed compatibility
all memory will operate at the slowest speed chip unfortunately. the only way to get the higher speed is to have all chips capeable of that particular speed.
Feb 14, 2009 | ASUS Computers & Internet
When ordering ram memory for wifes computer
Go with Crucial. I recently used then as the vendor to get memory for a middle school and all of their memory fit with no problems, the shipping was fast and the scanner worked with new and old computers. I would go for the pc2700, although your wife's computer can take both types, faster is better and the higher the number the faster the ram.
Dec 14, 2008 | Dell OptiPlex GX260 PC Desktop
ASUS A7S333 Motherboard Logo
169 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
