Question about Home
Clunking noise in sink
When we turn on the hot water in the downstairs bathroom, it makes a VERY loud, fast, clunking/vibrating sound. Some characteristics of the sounds are:
It only does this on this sink in the whole house
It takes a moment for it to start (probably coincides with when the hot water comes in)
The noise sounds like it is coming from within the bathroom, ie, it does not seem that the noise is coming from the adjacent laundry room where the other pipes are.
Any ideas?
  • 10,865 Answers
You are describing a problem known as water hammer. This will ultimately cause damage somewhere in your plumbing system so it should be addressed. If you are handy you can install an air chamber near the sink. If you want more information let me know. good luck.
Posted on Jan 18, 2009
  • 24 Answers
Air in the water line causes this hammering effect. It is called water hammer. This is a simple fix a plumber can do in about 30 minutes if he is an honest plumber. You just need a water hammer arrestor. It is a small L shaped piece attach inline that stubs off the side of the hot water pipe. Hopefully you know a neighbor or friend that would do this for you - cheaper than a plumber!! Search water hammer or water hammer arrestor in a search engine and you should be able to find a link that will show you a picture of what I am describing. Good luck.
Posted on Jul 04, 2009
I have 2 bathrooms with a common wall. We hear a constant low tap of the pipes in the wall between the bathrooms. We have checked toilets, sinks, faucets, etc for leaks. Sounds as if there is pressure or...
You have water hammer effect it is caused by a fast closing valve,it can be solved by installing a water hammer arestor in the plumbing line or maybe the water pressure is too high and a pressure reducing valve can be installed in the main water line.(the pipes in the wall are not secured properly that's why they vibrate)
May 19, 2011 | Plumbing
When hot water is turned on the pipes make this vibrating sound. i have two sinks in my bathroom. When I turn the hot water on on sink 2 the pipes vibrate. Sink 1 is fine.
There is a loose washer in the faucet...this flaps as the water goes through it and makes the vibration...
You either need to replace the faucet or the cartridge (washer) in the faucet that valves the water...
This will stop that vibration and hammering sound
heatman101
Aug 22, 2010 | Kohler Plumbing
Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
Jul 03, 2010 | Rheem Direct Vent Natural Gas Tankless...
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
LOW WATER PRESSURE IN downstairs bathroom sink
If it has a filter on the tip remove it and retry.
Feb 25, 2010 | Delta Plumbing
Loud hammering noise with vibration on piper when the cistern fil
You're experiencing "water hammering" it's solvable too.
You can buy anti-hammer add-ons which you can put under a nearby sink, or even on an outside hose bib. This will give the water pipes an air "shock absorber"... since air compresses it cushions the abrupt changes in the pressure where as if it's just water, it'll slam and hammer and vibrate...
Try an anti hammer device added to you supply... you should be able to add it with out too much tearout.
K
Jun 18, 2009 | Caroma 270W-RF Reflection Round Front...
Our new LG dishwasher makes loud clunking noise
I believe this is a brand new dishwasher. Please listen carefully to determine of the sound you hear (clunk) is being made inside the dishwasher or is it being made near by. Most times, the problem is that the hot water pipe is baking the noise when the dishwasher closes the water inlet valve ... and the pipe goes "clunk"
I have not had an LG dishwasher make a clunking sound inside itself when the cycle changes. Also, because this dishwasher is so very quiet (well insulated) the pipe banging would be louder than something inside the Dishwasher.
If you have access to the hot water pipe, listen very near it when the cycle changes for the sound. Follow that pipe (hot water) pipe back and insulate it at the point it is banging. (or get a plumber to evaluate and resolve.)
Please get back to me with what you find, OK?
Good Luck!
Apr 06, 2009 | LG LDF6920ST Stainless Steel 24 in....
Thundering noise coming from hot taps,bath,sink taps...
Sounds to me like you need to have a water hammer device installed into your plumbing, I have only run across this just once before, the noise is very loud and very bothersome, you will need to contact a plumber and have him install a water hammer device into your system, also vibration dampers would probably help as well, if your water lines are running through floor joists and touching them, hope that helps
Jan 18, 2009 | Bosch Exxcel KSR34423 Refrigerator
Water supply line vibrates making very loud noise.
these vibration in water pipes or cooper lines come from air in thewater supply system..dont take your appliances apart...
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Home Logo
691 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
