Question about Kenmore Elite 45986 Front Load Washer
HE4t kenmore washer rubber drum gasket not attatched.
The drum gasket is not attached in front and it's leaking water. I opened up the bottom front panel and it looks like the counter balance came loose and is laying in front of the motor and filter. (looks olike a large piece of concrete) I've changed the pump once and cleaned the filter a couple times.
  • gjfoss Jan 22, 2009
    i posted my own fix.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Posted on Jan 19, 2009
Water is leaking from the rear of the drum on our Kenmore HE4t. I've had the back off the machine - there is black (grease) running down from the hub, water leaking from there down onto the floor. How...
that would involve changing the outer tub (the only way to buy the tub seal) and the inner drum. big job and very costly as any warranty is from sears and they will only give you parts for free if you pay them to put them in for you too.
Feb 07, 2010 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Water is in the bottom of the washer after a day
are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Water leaking from bottom of door during wash cycle
this will more likely be your door seal open the door pull your seal so u can see inside and feel around as u look u will more than likely find a hole the water looks like it comes from somewhere else but it will be from the hole in the door seal seen this with hundreds of washers m8
Aug 26, 2007 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
595 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
