Older. bought it used last year
Hello megang665 - If the unit is inoperable there are a few possibilities that can be causing this issue. First, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately. The unit could have a faulty door lock, timer, pump, or control board not communicating correctly.
SOURCE: frigidaire dryer
There is a switch under the lid,Look for a slot onder where the lid rests on the dryer,there is an actuator under there where the dryer lid when shut should avtivate,this switch is either bent out of place,or the little pin that hits it when shut is missing or broke off.
SOURCE: Does anyone know where the reset button is on an
Make sure your breaker is "RESET". turn it all the way OFF, then back to ON.
SOURCE: need repair manual
You can find parts breakdowns and drawings for your dryer. Also can get help. Let me know, Sea Breeze
(click link below) enter model FDG436RES into model search feature and it takes you to 3 models, just choose one they are basicly the same.
http://servicepartstec.blogspot.com/
SOURCE: Frigidaire model # FDE336RES2 Wont turn on.
The fuse is located on the rear wall upper right hand corner. To get to it you must bust dat dryer down. HERES HOW
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
