Question about LG WM1814CW Front Load Washer
Door remains locked after cycle is finished on my LG washer
On my LG front load washer (WM1814CW), the cycle has finished but the door won't unlock, even though it is making the clicking sound as if it's trying to unlock. However, the Door Locked light remains on, and my clothes stay locked inside.
  • 1 more comment
  • Anonymous Jan 25, 2009
    We have the exact same problem. LG told us to unplug the machine and should reboot. Didn't happen. This is the second big problem we've had in two years; the first was the water pump seal. $300 later it worked. Then we had the LE error and had to use less soap.
  • displeased Jan 27, 2009
    it sticks often, but a re-rinse and all was good - but completely locked shut this time! tried everything.
  • thomas thompson May 11, 2010
    BAD LOCK SWITCH
  • 298 Answers
SOURCE: need service manual for LG
you can go to appliancerepairplanet.vstore.ca to get a sevice manual
Posted on Dec 20, 2010
  • 1294 Answers
SOURCE: LG front washer WM1814CW error OE
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 16, 2008
MNTECH
  • 1543 Answers
SOURCE: Can you adjust the water level on the LG Tromm WM1814CW?
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Posted on Apr 07, 2009
CMV9
  • 594 Answers
SOURCE: LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Posted on Apr 13, 2010
TheMobilian
  • 8220 Answers
SOURCE: LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
Posted on May 20, 2010
Electrolus front load washer door won't open
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Nov 20, 2012 | Electrolux Eiflw55hiw Front Load Washer...
Washer wont spin and makes a clicking noise
I have a LG front load and it won't spin or drain... Can u please help me
Jul 01, 2012 | LG WM1814CW Front Load Washer
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
De comes on the front and wont drain wm1814cw
the machine is clogged is th hose kinked,try to push the start buton again,you should hear the pump come on and try to drain.when it stops,push the button again,when the door unlocks take cloths out.And put 1/2c of bleach in drum and let it soak a few hrs.Now start washer no clothes this may do it,after cycle put clothes back in and run clothes through full cycle.When ther done.Put in Draino-Drain opener gell only and let it set over nite,then run heavy duty cycle this well clean washes and clean pump.
Jul 26, 2010 | LG WM1814CW Front Load Washer
UE=Imbalance error
load too small
appliance tilted
May 20, 2010 | LG Washing Machines
Spin cycle appears to be broken. washer just hums
Humming can indicate a stalled motor...If a coin is jammed in the pump impeller it will often do what you describe...Check via pump filter access door...Good luck....Nomess
May 08, 2010 | LG WM1814CW Front Load Washer
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
1,246 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
