Question about Amana ABB1927DE Bottom Freezer Refrigerator
Clips missing from grill covering evaporator
I have an Amana 25 cf side-by-side refrigerator-freezer that has a grill at the bottom, outside area that covers the evaporator coils. One of the spring clips that holds it on to the frame of the refrigerator has fallen off and disappeared (probably in our recent move). Does anyone know where I can find these clips?
Many thanks,
RTS
  • rontsolis Jan 19, 2009
    Thank you.
    RJT
    President:
  • Amana Master
  • 2,651 Answers
You can put your model number in here, and look up the part and order from sears.
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Jan 19, 2009
My fridge(& freezer) started giving off a bad burnt odor then stopped cooling (amana 25 cubic/mod #afd2535fes). any suggestions as to what it might be?
You said it stopped cooling, does the compressor kick on, or is it dead? Is the condenser fan operating (the one that blows across the condenser grill by the compressor)?
Is your condenser grill clean? What indications are you getting specifically?
Jul 15, 2011 | Amana 25" Cu Ft French Doors Bottom...
How to take the front grill off?
the grill should just snap off with a pull, evenly from both sides. If coils can be accessed from the front, there are no more coils in the back. The screwed on cardboard in the back is covering a fan so it can pull air directly over the compressor and evaporate the water in the drain pan. You should periodically check to see if water is draining into the pan, if not, the evaporator may be getting heavy ice build up, therefor not cooling 100%
Jul 15, 2010 | Amana 25" Cu Ft French Doors Bottom...
I have an older Amana SRDE25TW which doesn?t freeze/cool properly
It was probably the faulty thermistor all the time.
Feb 26, 2017 | Amana Refrigerators
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Freezer/Evaporator motor replacement
On my Kenmore bottom freezer, the evaporator fan motor is located behind a grill in the top center of the freezer compartment.  Remove drawers and door.  Pop off the grill by pushing on the tab in the center of the grill and then dislodging one side.  If you see the fan and confirm it isn't working, then you will have to remove the  icemaker.  Disconnect the plug at the rear of the icemaker by pressing on both sides of the plug and pulling.  Then remove the three screws holding the icemaker and remove the icemaker (it will probably have water in it, not ice).
Push the icemaker female plug through the back panel.
Remove the temp sensor cover on the upper right side of the panel.  Careful.  You need to pop the cover loose, then slide the cover off the sensor.
Now remove the four screws holding the back panel and remove it.  Try not to let the panel hit the evaporator fins, which are directly behind the panel.  Also, you'll have to be careful to work the temp sensor up over the top of the panel.
You have clear access to the evap fan now.  Unsnap the temp sensor from the tubing on the right.  Disconnect the  evap fan wiring (left side) and another connector on the right.  Remove two screws, and you have the evap fan assembly in your hand.  Pull the fan blade off the motor shaft (friction fit) and loosen the motor retaining clip.
Voila! You have the old motor in your hand.
Good luck.
KentC
Sep 17, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Drs2662aw amana side by side
Sounds like you may have a restriction or blockage, may also be low on freon
Aug 23, 2007 | Amana ASD2326HE Side by Side Refrigerator
Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Jul 15, 2007 | Amana ABB1927DE Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
61 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
