Question about Dell 828FI 15" CRT Monitor
Dell Monitor Not Working
I have everything plugged in and my computer turns on but the monitor's screen is black with the LED light orange (standby). Please help!
We have no Video card add-ons.
  • Thomas F. Schneider May 11, 2010
    You have tried another monitor to elimate that as the cause?
  • 81 Answers
Well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
Posted on Jan 18, 2009
Problem with monitor
Since the monitor is working normally other than turn off, I suggest plugging it into a power bar with switch. The pad switch is probably defective in the monitor.
Mar 11, 2012 | Dell Computers & Internet
Monitor will not turn on? westinghouse model L2046NV black screen will not turn on what should I do?
Do you see an orange light on the monitor anywhere? Usually the light turns green when the monitor comes on, but its orange when in "standby" mode. If your monitor is plugged in and you get an orange light, that usually means that your video card has gone out on your computer. When your video card goes out, the monitor doesn't receive a signal from your computer, so it doesn't know it is suppose to turn on. So if this is the case, you need to replace the video card on your computer
If your monitor doesn't turn on whatsoever, and everything is plugged in correctly, then you need to get a new monitor or send this one back to the manufacturer for a defective replacement.
Hope this helps! :)
May 03, 2010 | Westinghouse L2046NV Monitor
WILL NOT LIGHT UP-COMPLETELY DEAD
Hope this helps! :)
May 03, 2010 | E-Machines eMachines Monitor E15T4
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Blinking Orange LED light on E151FP monitor
This monitor is know for a lot of parts that go bad, luckily they are usually the same ones.
If you are a technician or know one who can help you. Below is a list of part to repair/replace once the case is opened. (dont try this if your unfamilier with working on electronics.
1) F601= 2A Fuse
2) C605= 68uf 400v (must change)
3) R615= 0.68ohm 1watt
4) Q601= SSS6N60A
5) R613= 1Kohm 1/8watt (value changed to 2.3Kohm or higher)
6) R623= 4.7ohm 1/8watt (value changed to 7.2ohm or higher)
7) D604= 1N4148
8) IC601=UC3842B
9) C707 & C703= 1000uF 16V (must change, because of bad ESR value) secondary filter capacitor.
This problem of dell e151fp lcd monitor, you just need to resolder the inverter section (bad points or dry joint) and also check the capacitor value with ESR meter. It will solve your problems.
Sep 14, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Dell 828FI 15" CRT Monitor Logo
613 people viewed this question
Alun Cox
