Question about Necchi 3101 Mechanical Sewing Machine
Upper tension not right after cleaning & reasmbling tension knob
I took the tension knob apart following directions for reassemble. I am having difficulting with poor stitching unless the knob is way up on 9. I had original took it apart because the thread kept breaking. I changed the needle, put a fresh bobbin in and then the cleaning. Help!
  • jill May 11, 2010
    does your tension knob have a center screw that needs to be tightened?
SOURCE: NECCHI 525FA
I have a brand new 525FA. I can try to take a pic of it tomorrow for you. I may have to call my mom to see what part you need a picture of cause I'm not familiar with sewing machine parts at all. But I'll check with her. Or maybe you can take a pick of what you need to see. Then I can look at it, and take a pic of the same thing on mine.
Posted on Jan 14, 2008
  • 106 Answers
SOURCE: bobbin jamming
Sounds like it is the bobbin tension that is causing the problem not the top tension. Have a look in your manual it should explain how to adjust the tension. If you do not have a manual have look at this website if they do not list one for your model email them and they will help. Check out the threading page as well.
www.sewusa.com
Posted on Mar 30, 2008
  • 66 Answers
SOURCE: How do i thread the bobbin on my necchi 539
take out your bobbin and turn it the other way
Posted on Feb 03, 2009
louislevel_2
  • 374 Answers
SOURCE: Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
Posted on Mar 07, 2009
RickE1
  • 202 Answers
SOURCE: I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Posted on Aug 29, 2009
My JUKI 1541 S thread winder is winding too loose. How do I adjust it?
Are you running your thread through the small tension at the upper right of the machine before you run it down to the bobbin? If you are and it is still loose, turn that small white knob to the right to increase the tension on your bobbin thread. If that doesn't seem to be working, pull the two tension discs apart that you have run the thread through, and see if there is a piece of thread or something caught between them that is not allowing the tension discs to close as they should.
Nov 01, 2017 | Juki Sewing Machines
How do I rebuild the upper tension mechanism for a singer sewing machine model 507?
It's far too complicated to explain on here. You need to get a service manual for your model, or find one with a similar dial. Make sure the manual covers tension dials. Getting the spring wound correctly can be a challenge. Have you checked to see the if the presser foot lever is pressing against the tension dial from the inside of the machine?
Mar 01, 2015 | Singer Sewing Machines
Upper tension won't adjust
You can try "flossing" the tension with a piece of unwaxed dental floss, a dollar bill, or a piece of fabric to try to clean anything that is trapped between the tension discs loose. Be sure the pressure foot it up and the tension knob turned to "0" before trying this. Then dial back the tension to your normal setting and try re-threading your machine. If this doesn't work and you know how to remove and reinstall your tension assembly, that could be the next step. The tension discs do wear out over time, but sometimes it is just some lint that needs to be cleaned out.
Chris
Mar 26, 2014 | Kenmore Sewing Machines
Thread tension control knob parts list.
There are just so many kinds of tension control knobs. Do you have a photo or model number?
Jan 30, 2014 | Simplicity Sew Precious SWSP2 Mechanical...
Rust inside of tension dial
If your tension knob is on top of the machine, it should be possible to unscrew the knob anti clock wise. Make sure the spring and other washers are not jumping out. Also check the position of the parts to know how to place it back into position once you finished cleaning.
Jan 12, 2014 | Singer Sewing Machines
How do i fix sewing machine tension?
#1 rule in dis-assembly of anything is to lay out the parts in the order they came off. I do this with a piece of tape turned sticky side up on my table. (for future reference)
As for your machine.. since you did not provide a model number the best I can offer is this parts page which has some diagrams under each model. Please locate model from the several pages listed... and view the diagrams.
http://parts.sears.com/partsdirect/getProductType.pd?parentCategory=Laundry+%26+Garment+Care&productType=Sewing-machine-Parts
Aug 19, 2012 | Kenmore Sewing Machines
I have a singer futura xl-400 and I am having a problem with the machine
It sounds to me like your bobbin tension is off. Take the embroidery unit off and set the upper tension to "S". Run a line of straight stitches, then a line of zigzag stitches. It is helpful if the bobbin thread and the top thread are different colors for this. If the top thread is almost a straight line, your bobbin tension is too loose. If your bobbin tension is almost a straight line, your bobbin tension is too tight.
To adjust the bobbin tension, take the bobbin case out and locate two screws on the side. The one you want is the straight-slot screw on the left; leave the Phillips on the right alone. The rule is "lefty-loosy", "righty-tighty" turn in the correct direction only 1/4 turn and sew another line; you should see SOME improvement, but it may take repeated attempts to get it in balance. When it is, put the unit back on, and don't forget to change the upper tension to "E".
Feb 15, 2012 | Sewing Machines
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
I just bought a used Husqvarna 2000 sl without a manual.
If you have on old Husqvarna 2000 from the 1970's, then the knobs are as follows:
Top front left: Pattern Selector
Top right: Stitch width
Lower: Stitch length and buttonhole (when turned to 0 and pulled out)
Extreme left: Upper tension
Side left: Presser foot pressure
Jul 19, 2009 | Husqvarna Viking 1
Necchi 3101 Mechanical Sewing Machine Logo
44 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
