Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
I need an installation wiring guide for a cozy wall heater. there is a transformer, gas valve,thermostat and thermo coupling. I believe it is a micro generator since it hooks up with two wires instead of a tube from the pilot.
  • 59 Answers
Go to www.cozyheaters.com for full install instructions.
Posted on Nov 24, 2010
How to install thermostat wires to furnace
that unit has a stat built into the gas valve, have to change valve to have a wall stat.
Oct 02, 2014 | Cozy (W352E) Heater
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
Do i need a low voltage transfomer to hook up my
what kind of thermostat to you have, did you purchase the thermostat with the unit are you upgrading to a electronic thermostat, If you are using the mechanical thermostat that comes with the unit you will not need a thermostat. please see the link below and page 11
http://www.wfc-fc.com/pdf/Monterey_Top_Vent_IOM.pdf
Jan 17, 2010 | Honeywell Programmable Thermostat Heater
I have a cozy gas furnace that only comes on when you bump it.
Hi loose connection in the heater or sticking fan or gas valve
Jan 09, 2010 | Cozy (W352E) Heater
I replaced the thermostat because it wouldn't turn on, it still doesn't turn on. What else can I check?
Jump the two thermostat wires together at the thermostat, if it fires up; it is a bad thermostat. Jump the terminals where the thermostat connects to at the gas valve, if the unit fires it is a bad thermostat wire or connection. If the unit does not fire, check for 24 volts AC out of the transformer. If yes, bad gas valve, if no bad transformer or no power to transformer.
Dec 27, 2009 | Cozy (W352E) Heater
Wires not connected to gas valve need wiring diagram for Cozy wall vent heater
I think you mean a milli-volt system. I went to the cozy heaters website and found the wiring diagram in an owners manual for a similar unit, a W355. I bet the wiring diagram will work for your.
Dec 10, 2009 | Cozy (W352E) Heater
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
146 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
