My asus laptop got really hot the other night, so i shut it down, it didn't turn itself off due to overheating, when it was cooled off and i turned it back on it wouldn't recognize that i had a charger plugged into it, checked the charger and it worked on another laptop, everything else on the laptop works fine.
Power adapters, also known as AC adapters, and batteries are used to power laptops. The power adapter comes in the form of a small box with a cord attached to each end of the box. Each laptop requires a different voltage and wattage to acquire the proper charge. When the computer does not recognize the power adapter, it can be an issue with the adapter or with the laptop. Plug the AC adapter into the laptop. Check to see if the charge indicator is lit. If it lights up then the computer recognizes it. Make sure that the adapter is compatible with the laptop. Test the outlet to be sure that it is receiving electricity. Wiggle the adapter and check the status of the adapter indicator. If the light does not stay on consistently, there is a short in the cord. Replace the laptop adapter with a new one that is compatible with your laptop. If the replacement power adapter is still not being recognized by the laptop, the motherboard could be the problem. Call the laptop manufacturer. If the laptop is under warranty, the motherboard can be replaced free. Hope this helps.
Maybe you did damage a component due to overheating? What caused the Laptop to overheat? Does the battery work on another laptop?
SOURCE: overheat?
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
SOURCE: dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
SOURCE: acer 5570 southbridge overheats and shutsdown
well,if you r able to get to bios then check power managment sction and reduce CPU speed and try to deactivate one of the peripherals that is responsible of thi shorting out= over warming.
as long as the southbridge chip over warms every time you turn on you laptop thats mean the S.B is facing a shorting out on it IC.
you can clean underneath/surround it.
plz rate.
SOURCE: Dell laptop charger
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
SOURCE: asus 1005ha netbook wont turn on
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena95
