Question about Mitsubishi LVP-X30 Multimedia Projector
LVP-X3004 Mitsubishi Projector
When I put the projector on, it flikers and then gives me flashed Message" Lamp".After that the message disappears and works fine for a while and it shut off by itself.I changed the lamp three times with three different new lamp, and I still have the same problem. Thanks for help
  • 31 Answers
Problem could be a fan problem or heat sensor or power ballast. Or at a board level a circuit board component failure - IC, capacitor etc Best to have it serviced by an authorised repair shop for Mitsubishi projectors. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Posted on Sep 09, 2009
I have a (Mitsubishi LVPX400U) and when I power up the word lamp flashes on the screen.
you will need to reset the lamp timer. Do you have a manual? probably hold down power video and computer buttons.
Apr 03, 2012 | Mitsubishi LVP-X400 Multimedia Projector
Red light labled LAMP stays on and I have no display of picture from projector
there is a problem with the lamp, hence why it will not switch on. Replace the lamp
Mar 31, 2011 | Mitsubishi LVP-X300 Multimedia Projector
How do i check the lamp life on the lvp-x300? how do i check the filters for dust?
For lamp life time, locate the UP, DOWN, and ENTER buttons on the keypad on the projector itself (not the remote) and press all three at the same time. The manual says you may get up to 2000 hrs., but we had to change ours at our church after 681 hrs., it was getting dim. There are filters on the bottom and front of the unit--find them and clean them!
Mar 12, 2011 | Mitsubishi LVP-X300 Multimedia Projector
Working but lamp warning on screen,lamp led flashing
Press < and > and Power buttons at the
same time on the projector to reset the
lamp hours counter
May 12, 2009 | Mitsubishi SL1U Multimedia Projector
Lamp timer reset
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the < > and POWER
buttons simultaneously.
Jan 16, 2009 | Mitsubishi LVP-S250 Multimedia Projector
Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Shuttle83
Nov 20, 2008 | Mitsubishi LVP-X80U Multimedia Projector
Projector won't turn on
Have you checked the user manual to find out what this "error message" means?
You may need to replace the lamp.
Jan 03, 2008 | Mitsubishi LVP-X80U Multimedia Projector
Power on.
try to feed projector from video and from pc or laptop if you get the same result from all signal sources you have a problem in main board and it needs to fix in good service center.
Aug 02, 2007 | Mitsubishi LVP-X70U Multimedia Projector
Mitsubishi LVP-X30 Multimedia Projector Logo
109 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
