Question about Cadet Manufacturing 67507 Heater
Cadet baseboard heater not working
I have a home with Cadet baseboard heaters. One has stopped working. The manual suggested checking wires, which are all connected and wired correctly. It then says that the limit may be defective and to replace it.
Where is the limit, how do I determine if it's defective, and how do I replace it?
Thanks
    Problem Solver:
  • 12 Answers
First... did this heater work properly in the past?? if not, the wiring may be incorrect..... but to answer your question the safety limit is usually on the left end of the baseboard (inside the small cover). it is the round thing that is installed inline on the wiring. replacing it is an easy fix... just be sure to turn off the electric power FIRST.
Posted on Sep 29, 2009
  • 24 Answers
The limit is a safety switch inside the unit to keep it from overheating if the fan doesn't turn on and is located inside the unit with what should be only 2 wires ran to it. you can determine if it is fauly by putting the leads of a multimeter while in the continuity mode, onto each lead of the switch, if the meter does not beep when this is done then it means that this switch is stuck in the open position and simply needs replacing. because it should automatically reset itself when it cools down.
Posted on Jan 24, 2010
If I have your information right you have a black wire and a white wire marked red coming to the heater with 240 volts between them. You have a double pole unit mounted thermostat with a red and a black wire. Most double pole thermostats have two red and two black wires on them so I am not sure if you have a double or a single pole thermostat.There are also two wires going to the baseboard heater. One is connected to the element the other to a high limit switch which is then connected to the other end of the element. If the thermostat is a double pole the two red (or load) wires should connect one to each of the baseboard wires. The two black (line) wires should connect one each to the two incoming power leads. If it is a single pole thermostat the one red wire should connect to one of the baseboard wires the black should connect to one of the incoming power wires the remaining baseboard and power wires should then be connected together. Hope this helps
Dec 12, 2013 | Heating & Cooling
Installing a cadet softheat hydrondic baseboard heater on 12-2 wire on 20 double switched breaker. Is this possible? I was told I could change the white wire to black giving me one black to each prong of...
Yes it is acceptable and common practice. You do not need a neutral on a 220 Volt circuit. Just wrap it with black electrical tape so anyone who gets into the wiring later will know that both are hot. This is accepted by the National Electrical Code.
Feb 13, 2011 | Cadet Manufacturing EBHA1000W The EBHA...
Cadet Thermostat
from the mod number it looks like you have electric baseboard. these do not have blowers in them they work off natural air movement. but heat up rather quickly. your gonna have to chk if baseboard is getting power to determine weather or not the t stat or the heater is not working. but first chk your circuit breakers. most heaters are 220v (double breaker)
Mar 19, 2009 | Cadet Manufacturing 6F1500W Baseboard...
Heater is excessivly noisy, can be heard over tv
first, my research into the Cadet model #09954 is a 240v unit. if it is wired to only 120v that may be your problem. I am not even sure it work work on 120v.
Feb 11, 2009 | Cadet Manufacturing 09954 Baseboard Heater
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
Baseboard heater cadet model
Check the circuit it is plugged into first with a tester or something else.
If it is 240v there are two hot wires.
You have to examine it first for power and then I would check the thermostat next.
You could have an open element.
Mar 25, 2008 | Cadet Manufacturing 09950 Baseboard Heater
Cadet Manufacturing 67507 Heater Logo
1,107 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
