Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Black water leaks from bottom of ProHeat 2x
Water dripping from bottom near wheels (looks like black grease or oil mixed with it). Happens after run soap/water dispenser for several seconds. It is not just dirty water from cleaning, but black oil or grease with water.
  • wadsjc Sep 01, 2009
    dirty water leaking out of bottom of machine
  • 350 Answers
Probably be a rubber seal leak or crack at the soap water dispenser pump.
If you can take it apart and it is the seal you should be able to reseal it with gasket seal from an auto parts store.
Posted on Jan 17, 2009
After cleaning the heater, my unit now leaks when it's turned on.
Hi there. Sorry to hear you're having difficulty with your ProHeat 2X leaking. You may want to contact one of our Authorized Service Centers to have a qualified technician inspect your machine.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 11, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
I HAVE A BISSELL PROHEAT 2X HEALTY HOME, IT WORKED JUST FINE THE LAST TIME I PUT IT UP. YESTERDAY, I NOTICED THE FLOW GAUGE WAS NOT SPINNING, SO I CHECKED AND SURE ENOUGH NO WATER WAS COME OUT. I CHECKED...
Have you made sure that the tanks are seated properly and the red
(or black) auto-load gaskets are in place.
Check the bottom of the Water Tank and the Formula Bottle to make
sure each has a red auto-load gasket attached and facing outwards.
You should be able to press the x-valve in the center of the auto-load
gasket so water or cleaning solution comes out.
May 17, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro Heat 9200 dirty water dripping out
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rujr
Mar 20, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My bissell proheat 2x wont vacuum up water
There is a float (usually looks like a red ball) that rises up if water is in danger of getting to the motor. Sometimes they stick.. Give it a poke to free it up.
All the best,
WD
Aug 18, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I used my new proheat 2x steam cleaner the first
You may have mislaid a piece when you took your Bissell apart to clean it after using it the first time.
I experimented with mine to try and reproduce your issue. On the bottom of the water tank, there are two pieces that can be removed from it. One of them looks like a black plug at one end, with a red rubber flange piece on the other end. If you push your finger inside the red rubber piece, you can feel a spring move up and down. This is the first piece you place on the bottom of the water tank. I suspect you have this piece, because if you didn't, water would gush out of the water tank as soon as you turned it over after filling it.
The other piece, which is the one I think you may have have mislaid, is a larger black, plastic ring with screw threads. This piece goes over the top of the first plug piece, screws onto the water tank, and holds the plug in place. The words "RECLOSE TIGHTLY" appear on mine. If this piece is missing, the water tank does not sit flat on the base of the Bissell, but kind of flops around, out-of-place, and the unit will not dispense water properly, though it may leak it.
If ithat piece is gone, it should be possible to reorder it. Start here:
http://www.bissell.com/Customer_Service.aspx
If that's not the problem, if you have all the water tank pieces, I wonder if perhaps you unscrewed one black screw to remove the clear front plastic piece from the base of the unit-- the piece through which water is drawn up off the carpet-- to clean it, and didn't get it back into place properly. Make sure the two hooks at the bottom of this piece are inserted, one per side, into the clear plastic side pieces at the bottom. If the hooks are not secured properly, before trying to reinsert them, unscrew the black plastic screw so you don't break the tab. It's easy to miss getting these one of those hooks back in right, but it's important to do that before trying to screw the clear front plastic piece into place.
Jun 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
NOT DISPENSING
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines.
Apr 28, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
497 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
