Question about Kenmore 15864/15862 Top Load Washer
Washer not pumping water out or spinning
We have a series 80 kenmore top load washer about 9 years old. We had a problem with it about 3 -4 years ago with the drive shaft and had it repqired. This moring we awoke to a wet load of laundry, dripping wet. My husband put it thru another rinse and it didn't drain. Could it be the drive shaft again or is it the pump? How do we tell and how would we repair. He has made repairs to our dryer.
    Novelist:
  • 101 Answers
It sounds like it's the pump. Tip the machine back and try to spin the motor where the pump connects. Make sure to unplug it first though. If it's hard to spin or it doesn't at all then the pump is stuck. Clamp off the hoses with hose clamps so you don't flood the house and remove the pump. It's just two clamps holding the hoses on and then the pump will slip right off the motor. There is probably something stuff in the pump causing it to not spin. It could be anything from a coin or a bobby pin to a sock or something. Clear it out and put it back on and it should fix your problem. I really don't think it has anything to do with the transmission. I hope this helps you out and if you have any other questions let me know. I will get a notification if you post anything to this message. Good luck.
Posted on Jan 22, 2009
Washer will not spin. water drains. motor runs. Kenmore 80 series mod # 23822100 please help thanks
With old washers and with new washers sometimes you have to get in there and tighten the belt or replace the belt. Your problem sounds like this to me.Your question was posted sometime ago and you probably found your problem. If not please get back to me and I will be happy to help some more. GOOD LUCK.
Aug 02, 2011 | Kenmore 23822 Top Load Washer
I have a 9 year old kenmore washer that just stops
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 22, 2010 | Kenmore Washing Machines
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series won't spin out
if the unit washes ,,and dont spins check your lid switch first...
Oct 25, 2008 | Kenmore 24902 Top Load Washer
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Kenmore 80 series
Lyzz, someone is going to have to check the pump for debris in it. It is not hard to get off, 2 clips and two clamps. You also want to check the drain hose from the pump right at the point where it exits the washer. I have found socks and other items stuck right at that point. You are going to have to remove the cabinet to get at the pump. Yours will have a cover under the console where you will have to disconnect some hoses. I will attach a couple of photo's to guide you...Catriver..post back.
Oct 18, 2006 | Kenmore 24982 Top Load Washer
Kenmore 80 series
I'm having the same exact problem, you posted this issue in Oct, have you found a fix?
Oct 18, 2006 | Kenmore 24902 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
97 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
