Question about Singer 7462 Mechanical Sewing Machine
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
The needle hits the bottom of the bobbin case and grinds against the metal. Also the bobbin won't thread. This happened after the material kept bunching.
  • Marge McCabe Jan 31, 2009
    I have and old touch and sew 758 with the same problem. Needle is hitting metal around the bobbin case. What to do?
  • matb6d Feb 09, 2009
    I am having the same problem. Just bought the machine today. Thinking about returning it unless someone can tell me an easy fix. All the lights flash and long beep when it happens. Can't sew.
  • 128 Answers
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Posted on Apr 21, 2009
Needle was hitting bobbin casing - reply was that the machine needs a hook timing adjustment - can I make this adjustment or do I need an expert?
Sounds like it's advanced.... but take it in and have it done professionally... have him lube and clean and check for cracked parts while you are at it.
Dec 29, 2012 | Singer Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
I was sewing along with no problem and then all of a sudden it jammed. I can't move the needle up or down without a lot of force.
There is probably thread jammed in the raceway area, take out the bobbin case and raceway if it is a front load bobbin
Aug 05, 2011 | Singer Touch Sew 7462 Mechanical Sewing...
Needle will not pick up the bobbin thread.
The first thing a person will say is that the machine is out of time. Thats very possible, but before you go to that extreme there are some other things you can check. Is the needle in all the way? Is the scarf in the needle facing the right side of the machine? Is it threaded correct?
May 22, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
New Problem...I have a Singer CG-550. When I try and sew anything, the needle hits something inside where the bobbin is. The little black casing holing the bobbin keeps moving all over the place, I slip...
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Mar 06, 2010 | Singer Sewing Machines
The needle hits way too low! Cannot sew any
You need to retime the machine, do not alter the needle bar it is very unlikey it has moved, email me for instructions drivewithken@blueyonder.co.uk
Nov 04, 2009 | Singer 7462 Mechanical Sewing Machine
Needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Oct 12, 2009 | Sewing Machines
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Apr 22, 2007 | Singer 7466 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
1,238 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
