Question about RCA Universal Remote Control
Tahnks will try that, do they have a starter relay or no
  • 11,896 Answers
Yes it does have a starter relay
I believe it is located Front seating area, driver side, behind dash, mounted above gas pedal
Pretty positive. If not there than it would be
Front seating area, driver side, driver side of steering column, behind upper dash panel, mounted above fuse block
Posted on Jan 18, 2009
Car won't engage starter
At the starter relay, you have two red or purple wires, one goes to the starter and the other comes from a 30amp fuseable link. Is that fuseable link circuit hot ?
From the key switch, power goes thru the alarm relay, then the clutch safety switch or automatic selector switch, then to the starter relay. The fourth wire on the starter relay is a ground.
You should be able to put power to the starter relay on the white or yellow wire coming from the safety switch to make the relay engage.
My guess is something wrong with the alarm system.
Mar 02, 2014 | 2004 Hyundai Tiburon
Car is out of gas and wont turn over
check fuel filter, fuel pump relay, or fuel pump. IF the car don't even crank over, (starter don't work) then:
READ THIS ALL BEFORE YOU DO ANYTHING
NOTE: some vehicles have the starter relay and starter mounted together as 1 unit. Sometimes the starter relay and starter are seperate. When I refer to "relay" it could also mean the starter and relay as 1 unit.
Note: "starter switch" is not to be confused with "key switch", although sometimes they are all one unit. The starter switch is usually mounted on the steering column and actuated by a metal rod. On units that are all one unit, the keyswitch/starter switch (both one unit) will have to be replaced. (this is a rare problem, so don't get worried just yet)
1. Check battery voltage, should be between 12.5-14.5 volts. if low voltage replace or charge battery, and try to start car, if it don't crank with new or charged battery, move on.
2. Check connections on the starter relay, even the small one coming from your starter switch. if loose or corroded, clean with a brush and reconnect them. Try to start your car. Did it start? if not, Move on
3. Well now we know the connections aren't the problem. How about a click? did you hear one? If a click is heard, go to #4, if nothing is heard, go to #5
4. Well at least the relay is clicking, but nothing else is going on. The relay is working, so the starter must be bad. Replace the starter and start your car!
5. Humm, connections aren't the problem, maybe the relay is bad, replace your relay with a new one. Move on
6. Now we have a new relay, with clean and tight connections. Start your car. Does it start? If yes, then HORRAY! we fixed it. Does it click? If so then goto #7, If it don't click, then goto #8
7. So here we have a new relay, with good connections that will click when trying to start the car, but nothing else happens. Starter is faulty, replace the starter, and off you go, see ya!
8. So here we have a new relay, with good connections, but it still won't click when we try to start our car. This means that your starter switch is faulty. Replace starter switch and try to start your car. Vroom! finally done with this car problem!
List of shortcuts: if you remove the starter switch lead (small wire) from the relay and apply +12v to its respective prong or lead on the relay, and your starter cranks, your starter switch is faulty. You can actually hook up a starter button this way. If you jump the two large wires together on the relay and it cranks, then the relay is faulty. If you jump the two large wires together and nothing happens, then starter is faulty, or wires to starter are loose or broken.
Dec 15, 2013 | 1999 Plymouth Neon
The car lights comes on but doesnt start
Dec 15, 2013 | 1998 Oldsmobile Cutlass
Car warms wont start
Dec 12, 2013 | Geo Tracker Cars & Trucks
Chrysler vision 1994 3.5
Dec 11, 2013 | Cars & Trucks
Car won't turn over. Battery & starter relay good.
  • READ EVERYTHING BEFORE YOU DO ANYTHING
  • NOTE: some vehicles have the starter relay and starter mounted together as 1 unit. Sometimes the starter relay and starter are seperate. When I refer to "relay" it could also mean the starter and relay as 1 unit.
1. Check battery voltage, should be between 12.5-14.5 volts. if low voltage replace or charge battery, and try to start car, if it don't crank with new or charged battery, move on. 2. Check connections on the starter relay, even the small one coming from your starter switch. if loose or corroded, clean with a brush and reconnect them. Try to start your car. Did it start? if not, Move on 3. Well now we know the connections aren't the problem. How about a click? did you hear one? If a click is heard, go to #4, if nothing is heard, go to #5
  • List of shortcuts: if you remove the starter switch lead (small wire) from the relay and apply +12v to its respective prong or lead on the relay, and your starter cranks, your starter switch is faulty. You can actually hook up a starter button this way. If you jump the two large wires together on the relay and it cranks, then the relay is faulty. If you jump the two large wires together and nothing happens, then starter is faulty, or wires to starter are loose or broken.
Dec 10, 2013 | 2002 Oldsmobile Aurora
Some times key turn but does'nt start
Dec 10, 2013 | 1998 Mercedes-Benz C-Class
2005 FXDL (13k mi) starter does not engage when start button pushed on a small clicking sort of sound. never had any problem prior. battery is good, strong lights and gauges. no engine cranking. relay?...
i can solve that... just buy a lighter... and a gasoline.......
1st step.... poor the gas onto you bike...
2nd step.... ignite it....
tahnks junel sabando.. form baybay city Philippines...
Jul 29, 2009 | 2001 Harley Davidson FXDL Dyna Low Rider
2000 expedition EB air compressor problem or relay problem
You will have to access it from under the vehicle and it is located right behind the right headlamp. The wire colors will be LB/PK,DB/YE,LG/RD,GY/RD.
Feb 26, 2009 | 2000 Ford Expedition
Problems
Check the battery and the starter motor.
May 30, 2008 | 1992 Dodge Ram 350
Televison & Video Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
