Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Dishwasher does not fill with water
My dishwasher "runs" but no water comes out.
  • bendylan Jan 12, 2008
    i seem to have the same problem.
    master oshie, which plug are you saying we should remove? where is it?
  • 27 Answers
It sounds to me like the base safety float has been activated. This will cause the unit to cancel the program it is in and activate the drain pump, hence the "run" that you hear, but no water. You need to remove the lid and two side panels. If you see water inside the base, you know that the safety float switch has been activated. Remove plug from outlet and empty water from base (by tilting to left side and using sponge to syphon water) Restart unit and check where water is leaking from. Usually from a filling hose not correctly/tightly fitted; leaky inlet valve; leaky heater asembly. Hope this helps! C.
Posted on Jun 26, 2007
SOURCE:
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
My dishwasher is running but not filling? Water is on & connected but can't work out why it won't fill. Any solutions? Thanks
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 13, 2011 | Ariston Technologies L63SNA Stainless...
Runs through all cycles water doesnt fill properly
Dishwasher Trouble
heatman101
Feb 22, 2011 | Frigidaire Professional Series 24 in....
Turns on and runs cycle but does not fill with water
Here is a tip that will help you to find out why water will not come into thedishwasher...
heatman101
Oct 26, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My 363.1522* dishwasher is not filling with water. the unit runs, but no water is entering the washer during the cycle.
heatman101
Sep 07, 2010 | Kenmore 24 in. 15222 / 15229 Built-in...
No water comes in my kitchenAid dishwasher
you only need prime to pump water out if you are not getting water to D/W it is most likely the water control valve
Oct 23, 2009 | Dishwashers
GE dishwasher will not fill with water
is the filling valve on the inlet water working unscrew the connecting pipe and see if the water is actually comeing out of the pipe. sometimes when the tap runs at the same time it takes a lot of the water rather than the dishwasher getting it. depending on the pressure. otherwise it might be the ****** pump. try wd 40 on it. it might be jamming.
Mar 22, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
305 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
