Question about KitchenAid KGRS807SSS Gas Kitchen Range
Error Code F2E1
Gas Range KGRS807SSS Error Code F2E1
What's the fix and how do I get it to stop beeping every 30 secs?
  • pritig111 Jan 31, 2009
    same error code f2e1.range doesnot work
  • 350 Answers
Did you try unplugging it for a couple of minutes and replugging it?
This might reset the computer control.
Posted on Jan 17, 2009
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Error code F2E1 on new Kitchen Aid KGSK901 Gas Range
This looks like the system buttons was all pushed at the same time,need to switch main power off and then on again so the board can reset it self
Dec 20, 2013 | Kitchen Ranges
F3 error. Beeping wont stop.
Hi miketack,
If your Dacor is getting an F3 error code and wont stop beeping this is because of shorted oven temperature sensor or RTD. You can fix this by checking sensor harness and harness connection between oven sensor and oven control. In case that wiring is ok you need to replace oven temperature sensor (RTD). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
May 21, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
F2E1 message on range
I have a repairman coming to check it out.
Jan 25, 2010 | Kitchen Ranges
My kitchenaid architect series II gas range is displaying an error code of f2E1 and saying stuck/shorted key. How do i fix this. My oven will not work.
In most cases, this is an indication that the Electronic Range Control (ERC) is defective and needs to be replaced. The ERC controls all the features of the oven, so without it, you cannot turn the oven on or regulate the temperatures. You can attempt to reset it by unplugging the range for at least 30 seconds, first. Or you can try disconnecting each wire from the ERC and reseating it (one-at-a-time) to ensure you have good connectivity. However, if the problem persists you will need to replace the ERC.
If parts are required, you can purchase on line at the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these websites to be reliable, offer great service and the prices are usually cheaper than retail. The prices will differ between sites, so shop around for the best deals.
If the model number you have this listed under is correct, the part number for the ERC is 9762794. The cheapest website I could find it was on the Sears website for about $158. (Not a cheap part no matter where you look for it).
To replace (if necessary), follow these steps:
1. Make sure the appliance is unplugged.
2. Remove the screws that hold the back of the control panel in place.
3. Take note of the wire color coding BEFORE removing any wires from the ERC. Most control boards will have the colors printed on the board by the terminals. If yours is not listed, either write the wire color codes down or use a digital camera to ensure you note the proper placement of the wires.
4. Remove the wires from the control board and the screws that hold it in place.
NOTE: Most ERC boards do not come with the overlay (This is the plastic that covers the facing of the EOC with all the features on it). Remove the old overlay from the old board if you wish to reuse it and install it to the replacement board.
If you have questions, please let me know. I hope this helps you.
Sep 23, 2009 | KitchenAid KGRS807S Gas Kitchen Range
KITCHENAID KGRS807 ERROR MSG F6E0
Problem with the time keeping unit. You will need to reset the unit. Unplug it for 30 minutes then plug it back in. If that does not work then check for bad ground wires that are not fully grounded on the unit. If you find a problem and need to order the part you can order it at repairclinic.com
Feb 22, 2009 | KitchenAid KGRS807SSS Gas Kitchen Range
Replace oven UI -KitchenAid KGRS807SSS Gas Kitchen Range Problem
Unplug the stove for at least two minutes or throw the breaker for the same time. So far, has worked 100% of the time for me for all error codes. Apparently something gets out of whack and turning off or unplugging must reset the system.
Oct 19, 2008 | KitchenAid KGRS807SSS Gas Kitchen Range
Oven on our electric kitchenaid stops working and f2e1 error message comes on. It does this frequently
F2E1 is a fault code that indicates the keypad my be unplugged or has failed.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jun 22, 2008 | Kitchen Ranges
F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
KitchenAid KGRS807SSS Gas Kitchen Range Logo
534 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
