Question about Lexmark E232 Laser Printer
Tray-2 not recognized
E232 with additional 550 page tray:
Tray-1 selection is recognized in the driver (drop down box) but Tray-2 selection shows a circle and '/' backslash when 'moused-over'.
Have to select 'Tray-1' for operation.
If selecting 'Tray-2' or 'Automatic', the 'load media' error light stays lit and printer won't operate.
Printer has been in storage for about a year, was working properly when taken out of service.
  • 3 more comments
  • tony646 Jan 18, 2009
    Thanks, but there doesn't seem to be any kind of sensor in the bottom of the tray.
    Both trays are loaded with 1/2 **** each. It acts like there isn't any comms through the molex plug that connects the main printer to the lower add-on tray, but have no way to check. The plugs connect by virtue of setting the main printer on top of the add-on drawer, can't see anything once it's stacked.
    Thanks again, Smithbrother but the only two things in their KB that relate have to do with C77x and 52x printers, specifically, and in general terms they just say 'pull it off and put it back down again' and if that doesn't work, send it in for service - so that's where I'm at for now.
    Btw, I have all the manuals, including the factory Service manual for this printer but I haven't seen anything that gives me a clue - just the pinouts for J3 that connect to the outboard tray-2, I'll see if I can figure anything out tracing through the diagram, but it's pretty rudimentary, doesn't really show you much.
  • Thomas F. Schneider May 11, 2010
    Sorry that I could not be of more help.
    Try pushing the  tray down. Sensor based upon weight of paper?
SOURCE: Lexmark E232 - Tray-1 Paper Problem
Just take ruber band out and flip it. And put it back, It works. Main reason is rubber is dried. Frugalguy's suggestion worked for me. Thanks.
Posted on Oct 06, 2008
SOURCE: Somebody has messed with the settings and now whenever we print we have to press "Select" for each page
The tray 1 is same as manual tray, it opens in front of you.
normally (in windows) you need to configure printer driver from printers => properties => printing preferences.
Posted on Oct 14, 2008
Corysf62
  • 188 Answers
SOURCE: How do we add an additional paper tray to the existing printer?
from the printer menu, go into the paper menu, change the "default source" to tray 2.
Also, on each computer that you have the driver loaded on, you can right click on the printer icon, go to properties, and select your default printing options.
Posted on Oct 30, 2008
SOURCE: Stopping Auto Tray Selection
If you use different print materials of the same size in the trays, each tray with a different print material should have a unique paper type setting to prevent the printer from linking the trays together and mistakenly printing on the wrong paper.
From the printer's operator panel, choose the paper menu, then paper type, then select the source (ie, tray) that you want to change.
For example, if you have plain paper in tray 1 and preprinted paper in tray 2 and both are set up where size = A4 and type = Plain paper then when Tray 1 runs out it will automatically feed from Tray 2. To prevent this from happening you should change Tray 2 type = Letterhead. In this way, the printer knows that the two media types aren't identical and won't pull from that tray unless you specifically tell it to.
Posted on Mar 10, 2009
reyjoshua07
  • 1157 Answers
SOURCE: Brother MFC 8460n paper pickup
Hi tkennedy0720,
Please follow these steps to assure you have made sure there is no jam.
1. Press the cover release lever to open the front cover.
2. Take out the drum unit and toner cartridge assembly.
3. Open the back cover.
4. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
5. Using both hands, gently pull the jammed paper out of the fuser unit.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back in the machine.
8. Close the front cover.
9. Press the cover release lever to open the front cover.
10. Take out the drum unit and toner cartridge assembly.
11. Hold down the lock lever on the right and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
12. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
13. Put the drum unit and toner cartridge assembly back in the machine.
14. Close the front cover. Pull the paper tray completely out of the machine. Use both hands to slowly pull out the jammed paper.
15. Press the cover release lever to open the front cover.
16. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
17. Put the drum unit and toner cartridge assembly back in the machine.
18. Close the front cover.
20. Put the paper tray firmly back in the machine.
21. Take out any paper from the ADF (automatic document feeder) that is not jammed. Open the ADF cover. Carefully pull out the jammed document to the left. Check for and remove any small pieces of paper stuck in the machine. A small piece of paper stuck in ADF will cause a document jam.
22. Close the ADF cover. Press Stop/Exit. If the Document is jammed under the document cover. Take out any paper from the ADF that is not jammed. Lift the document cover. Pull out any jammed documents to the right. Again, carefully check for and remove any small pieces of paper.
23. Close the document cover. Press Stop/Exit. If the Document is jammed at the output tray. Take out any paper from the ADF that is not jammed. Pull the jammed document out to the right.
24. Press Stop/Exit. If the Document is jammed in the duplex slot (only for machines which support Duplex printing). Take out any paper from the ADF that is not jammed. Pull the jammed document out to the right.
25. Press Stop/Exit. Make a Copy to test. Before placing your document(s) in the ADF verify the error message "Document Jam" in no longer displayed on the LCD. If the error message continues to appear on the LCD, please contact Brother Customer Service from "Contact Us". Verify the ADF document support (located on the top of the ADF) is pulled out. Verify the document(s) are between 5.8 to 8.5 in. wide and 5.8 to 14in. long. Make sure the documents are inserted face up in the ADF, top edge first. The ADF can hold up to 50 pages and feeds each sheet individually. Use standard 20 lb (80 g/m²) paper and always fan the pages before putting them in the ADF.
Note:
DO NOT use paper that is curled, wrinkled, folded, ripped, stapled, paper-clipped, pasted or taped. DO NOT use cardboard, newspaper or fabric. Make sure documents written with ink are completely dry. Adjust the paper guides to fit the width of your documents. This ensures the document(s) will feed straight, preventing jams. Make a copy listed below:
For MFC users :
Press Start.
For DCP users :
Press Copy located below the LCD and then press Start.
Hope it helps.
Thank you for using FixYa.
Posted on Jul 06, 2011
Kyocera fs 1920 installed on windows 7 64 bit cassette 2 not showing
Download the KPDL drivers and after they are installed go to the printer properties, then device settings and select how many paper feeders you have "in addition" do the 1st tray. So if you have two trays just pick "one" for that option. Then you will be able to scroll back up and choose what paper type it is.
Lastly, set your Printing Preferences in the properties if you want to specify a specific tray/cassette to print from or just let the printer auto select.
Jul 27, 2012 | Kyocera Mita FS-1920 Laser Printer
I use a CM2320nf MFP connected to Windows XP. The unit seems to be defaulted to print 2 pages - and for double sided copies, it stops after 2 pages, then the Cleaning window pops up, then I get an error...
Problem 1 :
As far as the machine printing 2 pages per job. To fix this it's usually the default number of copies the printer is set to. To change/ confirm the setting is set to one:
Press the menu button
Arrow down to -> Printing, Press the green check to enter the menu
Arrow down to -> Copies Press the green check to enter the menu
Change or confirm the value = 1, (Based on your question this might be set to 2) Press the green save the value.
* If your number of copies is set to 1 and the machine is still printing 2 copies, then the problem relays in your print driver.
Problem 2: General Misprint Error message something like 41.3
2 things to check:
1st - Press the menu button
Arrow down to Paper Handling, Press the green check to enter the menu
Now you will see options like Tray 1 size - Tray 1 type. Here their will be a option for each tray installed on your machine. You will go into each tray option and confirm the paper size and type.
Example
Tray 1 Size = Envelope #10 (This is the manual feed tray)
Tray 1 Type = Envelope
Tray 2 Size = Letter
Tray 2 Type = Plain
To perform arrow down to tray X size press the green check to access the menu, arrow up or down to select your paper size. Once the paper size is selected press the green check to save it. repeat for each tray.
2nd -
Pull out your tray and remove the paper, towards back of the tray you will see a guide (Tab) in the middle of the tray which allows you to expand the tray to accept various paper sizes, Please confirm the guide is set to the correct type. If your using letter, make sure the guide is set to letter (LTR) you can see these codes by looking at the base of the guide, their is a little arrow pointer.
Hope this helps
Jan 14, 2011 | HP LaserJet 2420 Printer
Trying to print photos from the photo tray. I can't find any place to select the photo tray. I've selected Photo and PhotoL paper, but it keeps printing from the main tray. Using Win 7 and driver...
pull out the paper tray. depress the blue button located to the right of the photo paper insert slot and slide the entire top section of the paper tray forward until it latches into place. be sure to place your photo paper finish side down. the printer will automatically recognize the paper size and select it for you by default. i assure you this will solve your problem. heres a link to the manual. the illistrations you need are located in chapter 2 page 13 and 14. please leave a testimonial on my page to show appreciation. thanks.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_495CW_EN_1855.PDF
Dec 18, 2010 | Brother MFC495CW
When I try to print a document the printer only wants to print from the photo tray. I am only trying to print a document. Any suggestions?
1. You will have to designate which tray that the printer uses in the printer setup page.
2. click "file" then on the drop down of the screen click "print" the select "automatic" for the tray select or use the drop down button and select the proper tray.
Apr 20, 2010 | HP Photosmart C5180 All-In-One InkJet...
Won't use tray 2 when tray 1 is empty
Have you tried checking that tray 2 has the same paper type as tray 1. If your machine is network attached, you can access the embedded web server (where device settings can be adjusted) by entering the device IP address into a browser. Find the web address from the machine by going to menu (key icon), reports, then arrow over to network set up page. NSP is a 1 page report which will tell you the IP address. Go to a web browser and type in that IP address. Should take you to your device web page. From that page you can change the device settings (click on settings and then paper menu). Check to be sure that the same paper type is set for both tray 1 and tray 2 (and be sure that tray 2 is showing up on the list). I had to power the printer back on for it to recognize tray 2. Hope it helps
Feb 04, 2010 | Lexmark C544dn Laser Printer
Hello, I have an invitation that is 4in wide x 9 inches in height. I want to print something on it, but not sure how to get my printer to recognize that I am using custom size paper. It keeps printing on...
In addition to the wide variety of standard paper sizes available for this printer, you can use custom size paper in the Tray 1 (MPT).
The size range for custom size media is as follows:
    Minimum allowable page size:
    89 x 140 mm (3.5 x 5.5 in.)
    Maximum allowable page size:
    216 x 356 mm (8.5 x 14 in.)
  1. Open Tray 1 (MPT).
  2. Insert the custom size paper and adjust the guides to match the size of the paper. Place the side to be printed facedown with the top of the page entering the printer first.
  3. When the front panel prompts you to confirm the type and size of paper:
    1. Scroll to Change by pressing the Down Arrow key and press the OK key.
    2. Scroll to the correct paper type and press the OK key to save your selection.
    3. For the paper size, scroll to Custom and press the OK key.
    4. Select Set Custom Width (W) by pressing the OK key.
    5. Press the Down Arrow or Up Arrow key to scroll to the desired value for X and then press the OK key.
    6. Scroll to Set Custom Height (H) and press the OK key.
    7. Press the Down Arrow or Up Arrow key to scroll to the desired value for Y and then press the OK key.
  4. Select the custom size in the printer driver.
  5. Windows 95 / Windows 98 / Windows Me PostScript driver: On the Setup tab:
    • After you select the Multi-Purpose Tray and the tray displays Custom to indicate that it has custom size paper, enter the dimensions of the custom size paper in the Width and Height boxes.
    • If you select Automatic for the paper source and select Custom Size for the paper size, enter the width and height values of the desired custom size paper in the Width and Height boxes. The values for width and height are initially 0. If you previously entered information in the boxes, the values are automatically entered.
    Windows NT / Windows 2000 / Windows XP PostScript driver: On the Paper/Quality tab:
    • If you select Choose Specific Tray, select the Multi-Purpose Tray.
    • If you select Automatic, you can select your custom size from the Paper Size drop-down list.
    • Click My Custom Sizes and highlight the custom size in the Current Selection list. The Name, Width, and Height boxes display the details about the highlighted custom size and the sample image changes to represent a scaled version of the custom size.
    • To create a new custom size:
      1. Click New.
      2. Enter the new name in the Name box.
      3. Enter the dimensions in the Width and Height boxes. The sample image changes to represent a scaled version of the new custom size.
      4. Click Save to add the new size to the list. Click Cancel to exit without saving the new custom size.
      5. To exit, click Close.
    • The My Custom Sizes box lists existing custom sizes that are supported by the current printer. Since these custom sizes are saved in your computer's operating system, they are available for you to select in your applications.
    • If you create a custom size in certain applications, the driver lists the custom size automatically.
    MacOS 8 / MacOS 9 driver:
    • In the Page Setup dialog box, click on Page Attributes, and select Custom Page Sizes. Then press New to enter a new custom page size. A dialog box appears where you can enter the width and height, margins, and name of the custom page size.
Jan 19, 2010 | Xerox Phaser 6250 Laser Printer
I want to print from Tray 2 where I have letter size paper. The printer is telling me to load paper into tray 1 -Error message is 41.3 Unexpected Paper size. I need the printer to select from tray 2 unless...
Assuming the printer is otherwise working ok and we are talking about a Windows operating system....
When you choose the Print command from the drop-down menu in your application, instead of just proceeding, choose "Properties" or "Preferences" in that window. This should open up another dialog window from which you can choose additional printing options. It may be under Advanced or Tray Select, etc.
You can also get to the printer dialog windows by clicking on the Start button, then Settings, then Printers and Faxes, then double-clicking on the printer icon in that window for your printer and proceeding from there.
Jan 02, 2010 | HP LaserJet 4050n Printer
T642 wont recognize tray 2 or duplex
You need to be sure you add the duplex unit and tray unit in the windows driver. The "device" tab will allow you to add the duplex and tray to the
printer.
Apr 29, 2009 | Lexmark T642 Laser Printer
Tray 3 is not showing up at all in the printer properties dialog box. Any suggestions?
Have you re-installed the driver recently? Perhaps you didn't install the correct one. for example '4200tn' (the "t" standing for 'tray"). If you have only installed the regular 4200 driver, then tray 3 will not show up by default
However, you can add it to the current driver as an option.
"Right click" the printer icon
Select "properties"
Select "device settings"
under "installable options"
Click on "tray 3 -not installed" to open drop down menu. click "installed"
Please rate my solution :)
Apr 15, 2009 | HP LaserJet 4200 Printer
Oct 14, 2008 | Lexmark T632 Laser Printer
Lexmark E232 Laser Printer Logo
148 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
