Furnace restart I have a residential Day and Night furnace. When it shuts off it cycles very briefly 3 times ( blower) before shutting down. all other aspects are in working order.
  • 1 more comment
  • tkhinrichs Jan 18, 2009
    It sounds as if the blower just starts and stops right after it reaches temp and shuts down ( on avg. about three times, less than second each). the ignition does not go off
  • tkhinrichs Jan 19, 2009
    Thank You will try
  • Perry Putnam
    Perry Putnam May 11, 2010
    When you say it cycles are you saying that the flames come on for a few seconds, shut off three times. Then the blower comes on for a period before it tries to ignite again?
    Scholar:
  • 144 Answers
What kind of ignition is it? If it is a Hot surface igniter(glow coil) look for a small, maybe 3-4 inch long rod that is mounted to or near the burner. It's probably on the burner on the side away from the igniter and would be in the flame when the burner comes on. Clean it with sand paper. It's a flame sensor and the igniter is sending a small amount of voltage through the flame(fire is a conductor) to the sensor and if it's dirty it won't complete the circuit. If after cleaning it works then great you need to get a new one within a few days. If it doesn't work then the igniter is probably weak and needs replacing but it could be something else so I would call for service instead of guessing.
Posted on Jan 18, 2009
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
I have a builder installed Goodman GDS80904BHA that is approximately 5 years old. Recently, when the furnace completes a heat cycle, approximately 1-2 minutes after the cycle has completed and after the...
I would guess that the fan off setting on your limit is set a little to high. If you have the manual you can see what it says about changing the running time for the fan after the burner has shut off look on the control board and you should see two switches,one to set the time for burners to fire before main blower starts and one to set time for fan to run after burners shut off. To help with the problem you are describing set fan run time up so fan wii run longer. Hope this helps. Thaks.
Nov 22, 2010 | Goodman GDS80904BNA Open Flame Heater
Fan will not shut off after heat cycle is finished. Need to shut off power to furnace. GMP100-3
Are you talking about the indoor fan. Some have a time delay to allow the blower to cool the furnace and make use of the heat built up in the heat exchanger.
May 04, 2010 | Goodman CKL60AR60 Air Conditioner
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
My heater will kick on right away but after 3-5mins it stops producing heat then a few mins later it will start heating again. Why?
The furnace could be shutting off on High Limit ...means your furnace is running too hot...check your filter and make sure return air vents are clean and clear....also it can be the Heat anticipator in your thermostat...which controls how many times your furnace cycles...basically your furnace should come on and off 5-6 times/hr ....need more info on your type of furnace and type of thermostat
Oct 19, 2009 | Holmes Products HCH4062 Ceramic Compact...
Red light blinks 4 times, will only cycle once
the high limit is sensing the internal temprature of the furnace.If your filter is very dirty or you have to many of the registers/dampers shut it will cause the temp. of the furnace to exceed its rating and the high limit will open the circuit and shut down the flow of gas. Your blower will then run until the furnace has cooled and the switch will close and allow it to come back on. This is bad for your furnace, make sure your filter is clean and you dont have to many registers shut. If you have run the unit without a filter the problem could be much more sever requiring blower wheel and coil cleaning and possibly a cracked heat exchanger.
Sep 12, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
