Sharp 13K-M100 13" TV
Problem for Sharp 13K-M100 13" TV
Gfci trips
By autojoe on Jan 17, 2009
gfci trips.it protects 4 receptacles downstram from it.If I disconnect from downstream receptacles it will not trip.This is on kitchen counter-top circuit.All wiring and devices are only 6 months old.Someone told me maybe some moisture got in one of the receptacles.I was going to try disconnecting farthest receptacle and try gfci and see if it trips and then work closer to gfci and see where problem lies.I don't know what else to do.I tried 2 different gfci's.Any ideas?Thanks,joe
Solution #1
posted on Aug 26, 2009
Not Rated)
joshualp1
Rank: Guru
Rating: 90%, 34 votes
There can be a few different reason for a trip. 1. Amps exceed rating off GFCI ie 15 amp receptacle can only handle up to 15 amp anymore and it will trip. 2. miss wiring; neutral must be on white screws hot on black and ground, green also inlet power (line) must be on bottom screws, outlet or load must be on top 3, a short, whether it be neutral or hot touching something in the box. Frayed wire, wire next to side of interior of box or yes moisture. Also a short in an appliance aven a new one can cause a trip. Remember if the refrigerator is on this same circuit, which is not a good idea it can cause a trip. At start up the fridge can spike to near 15 amps and a voltage spike can cause a gfci to trip. There are 20amp GFCI's so that can be your last resort, if all else fails.
Was this helpful?
Yes
No
Popular Solutions for Sharp 13K-M100 13" TV
Questions and Unsolved Problems for Sharp 13K-M100 13" TV
Do you recommend Sharp 13K-M100 13" TV?
Answer
Answer
what is the resolution of the sharp 13km1000
Answer
hi--can anyone please just tell me where one attaches the antenna on the Sharp 13K-M100? thank... (More)
Answer
Can I get a list of codes to program my orion tv to my Time Warner Remote?Thanks for any help.
Answer
Can I get a list of codes to enter in to my remote, so the Time Warner Cable remote will control the... (More)
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
