Question about Denon AVR-1802 Receiver
Denon AVR-1802 Hi there, I had a Denon 1802 AV receiver and it went into protection mode a week ago. I went all over the web looking for fixes. All of your posts on problems like this were the most helpful. I was wondering if you could guide me a little. I have taken the unit apart and isolated the faulty IC using a DMM. It is the one closest to the back of the unit and has D2390 stamped on it. On the PCB board the numbers read 2SD2389 and Q101SL. I looked all over for a service manual with no luck but I don't think I'll need it. I was wondering where to go from here... Where to puchase a new IC? I have decent soldering skills and don't think that'll be an issue. Is there anything else to check for? Any help and information is appreciated! Thanks, Mark
  • 431 Answers
Providing we are talking a standard tall pin Ic ie not a flat surface mounted variety you shouldnt have too much trouble with the soldering as long as you have a steady hand .. remember not to leave the iron on the joint too long or the print will lift and keep the tip clean to aid heat flow to the solder .. here are a couple of web adresses that might help you get the components you require and good luck oh by the way dont forget static precautions , touching an Ic alone without gorunding yourself first with a static strap can blow some sensative ic's http://www.rscomponents.com and http://www.maplins.com also http://www.radioshack.com
hope this helps and again good luck . .... Reagards ..Vortash
Posted on May 02, 2009
2 Suggested Answers
  • 4234 Answers
SOURCE: A/V needs new insides... which parts and numbers
First of all the part is a transistor not an IC. There should be at least 4 of these on the back, two of which will be marked D2390. The other should be marked Bxxxx. If the leads of the one you removed read 0 ohms, then it is shorted and must be replaced. You should also replace the 2SB compliment as well.
Before replacing them, completely remove all 4 and mark their locations. Turn on the unit and see if the protection message goes away. Hopefully it will. If it does, carefully measure using the DC voltage setting on the meter the 3 pads for each of the two transistors on the bad side. The readings should be something like 0,+/-40, and +/- 0.6V. If not, please post the readings here and we'll move onto the next step. Otherwise, replace the trnasistors with new ones and you should be OK.
Dan
Posted on Feb 07, 2009
Why does my new AVR X1000 keep going in protect mode
It only goes into protect mode usually when there are to manny speakers hooked up more then its can handle
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
My Denon AVR-1802 is permanently stuck in tone defeat. The display actually shows that the tone defeat can be turned off and on, but the tone controls, ie. bass and treble do not alter the sound in any...
Is this only when using external inputs? The manual says the Tone Control will not function in Direct Mode. Try Stereo and various DSP surround modes to see if the Tone Control works.
Apr 21, 2009 | Denon AVR-1802 Receiver
Dan
Feb 06, 2009 | Denon AVR-1802 Receiver
DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Jul 21, 2008 | Yamaha RX-V461 AV Receiver
Digital audio cuts out.
I have same DD 5.1 tiny "bursts" problem with satellite HD channel. It is probably problem with Crystal DSP (German site): http://forum.digitalfernsehen.de/forum/showthread.php?t=89328&page=3
"Denon bietet Lösung für EX-Flag-Problem bei den Modellen AVR-1602 und AVR-1802 an
07.08.2002(cr)
Dass die Denon AV-Receiver AVR-1802 und AVR-1602 die mit einem DD 5.1EX-Flag versehenen Tonspur von "Atlantis" und dem "Herrn der Ringe"nicht abspielen können, ist ein spezifisches Problem von einerbestimmten Revision des in diesen Geräten verbauten Crystal DSPs.Dieser Chip wird u.a auch in einigen Kenwood- und Onkyo-Modelleneingesetzt.Da es von diesem Crystal Chip unterschiedliche verbauteRevisionen gibt, von denen aber nur eine bestimmte betroffen ist,werden die beiden Filme auf dem größten Teil der verkauften AV-Receiverohne Schwierigkeiten laufen.
Denon bietet nun für alle betroffenen Kunden, die ihr Gerät beimdeutschen autorisierten Fachhandel erworben haben, eine kostenloseModifikation an. Das Gerät muss beim entsprechenden Fachhändlerabgegeben werden mit dem Hinweis auf das Herr-der-Ringe- bzw.Atlantis-Problem.
Momentan steht nur eine begrenzte Anzahl an DSPs zur Verfügung - Denonhofft, dass kurzfristig ein größeres Kontingent eintrifft.
Denon bittet daher die Kunden freundlich um Verständnis, dass nichtalle betroffenen Geräte auf einmal und sofort umgerüstet werden können."
May 23, 2008 | Denon AVR-1802 Receiver
Remote control for this model AVR 1802 is failed to work , i want spare
Many original remotes are exspensive and hard to get hold of , Radio Shack or Maplins have many universal remotes that not only will allow you to control your AVR 1802 but many other devices you have also ... at probably half the price . ... regards Vortash
Apr 17, 2008 | Denon AVR-1802 Receiver
Denon AVR-1802
might hav eto buy new control modual parts store hi end parts store order one for u
Jan 25, 2008 | Denon AVR-1802 Receiver
WIRELESS SPEAKERS
There are many kits at Maplins or Radio Shack that will do this for you , you can search for them at http://www.maplins.com or http://www.radioshack.com you may even be able to build one yourself from circuits available off the web .
Yes you will be able to use your own speakers and your options are basicaly down to what you can afford .... Regards Vortash
Jan 11, 2008 | Denon AVR-1802 Receiver
AVR 810 Denon Receiver Sub Woofer Hookup?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Dec 28, 2007 | Denon AVR-2106 Receiver
Denon AVR-1802 Receiver Logo
437 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
