Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Roller brushes siop after a couple of seconds
I have a new Bissell Pro Heat Select 2X and the roller brushes stop going after a couple of seconds. I noticed the motor stops running that drives the brushes. Is this normal? Any help would be greatly appreciated.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
87uyf
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My bissell proheat 2x 8920 has poor suction and wont spray water
take a tooth brush to the very back of the roller and u will free the dirt in the small holes at back
Mar 22, 2013 | Bissell ProHeat 2X Upright Deep Cleaner,...
Bissell pro heat 2x belt keeps snapping in half i have cleaned the brushes and stuff but it continues to do it
If hair etc bound to roller look for and remove that--make sure using correct belt and where it engages shaft the end is clean (black belt residue will cause belt to slip and early failure).
Nov 06, 2012 | Vacuums
The brushes on my Bissell Proheat 2x shampooer won't turn.
You need to replace the belts on the roller brush. Here are the belts you need:
Bissell Proheat 2X Belts
May 24, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
How do I change the belt on my Bissell Pro Heat
heatman101
twerw
Apr 16, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Brushes aren't turning on Bissell Proheat 2X and it is almost new.
New or old,flip the vacumm over,and remove the long hair and debris from the roller brushes. If they don't spin after removing any debris,the
belt,that turns the brushes has come off,or the motor is bad. You wil
have to take the bottom section apart,to see what's going on,then.
Good luck.
Apr 01, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Mar 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro Heat 2x steam cleaner, problems!
Must likely the brush motor is bad. The top cover has to come off to check it, this is where the tank sits on. Part # 2036757 and is #35 in the pix.
Mar 14, 2008 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
821 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
