Question about Admiral AW22 Top Load Washer
Samsung SW65ASP2 My cold water is not filling (very slow) It is not the tap or the hose. I have even change the mesh filters in the water inlet connectors. At the final rinse it stops and registers 7E on the electronic read out window. Can anyone help?
  • 27 Answers
If you are sure there is sufficient water pressure at the hose, then your inlet valve is on the blink....replace it.(the unit where your hose connects onto) Oshie
Posted on Jun 26, 2007
    New Friend:
What does de error means..
Posted on Aug 12, 2011
SOURCE:
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Does the top loader heavy duty machine have a filter and does it need to be cleaned regularly. If so, where is it located?
No filter to be cleaned in the machine. There are however small wire mesh filters in the screw on connectors that connects the water hoses to the machine at either the tap side or where it are connected to the machine inlets. Unscrew the hoses from the tap and machine inlets and check both hose ends if the wire filters are not to clog up over time resulting in slow water filling of the machine. Remove carefully and clean with a nylon brush. Replace again.
Aug 01, 2014 | Speed Queen 3.3 Cu.Ft. Heavy Duty Top Load...
Kenmore washer water not filling
there is a inline mesh filter at the tap end of the hose but it is more that likely that the tap washer need replacing
it is possible that the inlet solenoid valve is not operating properly
if you have separate hot and cold water hoses and taps then either tap should produce a full flow when set if no taps get a full slow when selected , indicates a problem power board
Nov 05, 2017 | Kenmore Washing Machines
My samsung triflow sw65asp2, the cold water is taking forever to fill the drum, the hot water seems fine. any idea what could be causing this?
(pre-typed for both hot and cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 25, 2011 | Washing Machines
I have a Whirlpool Ultimate Care II; when I choose cold water, it takes at least 2 hours to fill the tub. Warm water will fill but the cold water comes out in two very small streams. Any help would be...
You likely have either a folded cold inlet hose (squashed) or self plumbing tap that is rusted in the cutter so slow filling or a blocked mesh filter in the cold hose connection on the back of the machine, try all three and you should have the answer.
Sep 05, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The cold water inlet is slow to fill machine but the hot water inlet works fine
Hi just read your posting.Could you please supply the model of your hoover and tell me if it is a front or top loader.The fault on your machine is due to a faulty cold water valve or dirty inlet filter.Turn the cold tap off and remove the cold water hose from the tap end and check to see if the little filter at the end of the hose is blocked.If it is, clean it and put back the hose to the tap and try a wash cycle.Please reply with additional information and to tell me how you got on with the filter.
Jun 29, 2010 | Washing Machines
Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
Dec 25, 2009 | Roper RTW4300SQ Top Load Washer
Cold water fill is very slow and makes strange sound
check with the plumbing work if that is fine then better take it to the dealer to change the inlet valve. attempting to change by yourself can cause other complications.
Oct 04, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Washer will start cycle then stop and LF starts blinking on the screen
LF means long fill. So the washer is taking too long to fill. Make sure your hoses are connected to the right spot on the water valve. (hot on hot and cold on cold). Also check that the taps are fully open. If this is good remove the hoses from the washer water valve and put the end into the washer tub. Turn on the hoses and check for good flow. They're good? Check the mesh filter in each inlet of the water valve. All clean? Replace your water valve. Good luck!
Apr 28, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Water inlet
Have you checked the little mesh filter that may be in the hose? Sometimes sediment and other debris can build up causing slow filling. Turn the water valve fully off. Remove the hose from the valve and the machine. Check for a mesh screen in both ends of the hose, possibly even in the inlet to the machine. Remove and clean. You could also have a kink in the hose, bad hose (seen this too many times, just swap the hot and cold and see if the problem moves) bad solonoid valve, bad supply valve, etc.
Jan 04, 2009 | Frigidaire Washing Machines
Admiral AW22 Top Load Washer Logo
607 people viewed this question
Top Admiral Washing Machines Experts
jimorris77
Gerry Harvey
Gerry Harvey
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
