Question about Logitech 9311570403 Mouse
Jumpy mouse Ihave the wireless mouse and I'm having a problem with it, it jumps all over the place, I can't control it. What do I need to do? I also have the logitech keyboard it has all these functions but I never got a manual with it so I have no idea how to activate it.
  • marleneparri Jan 17, 2009
    yes it is a wireless mouse p/n 831843-0000 LZ 719AU, yes it's an acer lcd monitor and it runs vista. I went into the control panel to the mose slowed it down to see if that help but it didn't. It has done this since I bought it I should have taken it back but didn't . Works great except for that. I do have software but have bought so many different logitech mose I have no idea which software goes with this one.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this a wireless mouse?
    Are you using an LCD monitor?
    What operating system are you using?
  • 2,794 Answers
The easy way to do is to go to logitechs website and download the correct drivers. Model number is on the bottom of the mouse.
You could try relocating your transmitter attatched to the computer as well and see if that makes a difference.
Posted on Jan 17, 2009
    Genius:
  • Logitech Master
  • 1,102 Answers
Buy A Mouse Trap if the darn mouse is jumping everywhere
LOL
Did you just install and did come with any software
have you checked in control under pointing devices or mouse and see you have a setting in there
  • DEKR
    DEKR Jan 17, 2009
    if you can find the software i would reinstall it
    and did you check to see it's compatible with vista
    WAS ONLY KIDDIN ABOUT THE TRAP
    buying a mouse trap will not solve this problem LOL
  • DEKR
    DEKR Jan 18, 2009
    each cd should tell you which mouse it belongs to
    if you can find it i would run the setup again.
    if not you'll need to download those drivers again
Jumping cursors and letters
Step 1:
If you are a frequent user of a notebook or netbook computer, then you likely use a touchpad to navigate your computer's on-screen cursor. However, there are a number of issues that can cause your cursor to seem jumpy or unresponsive. To find what is causing these issues, you can troubleshoot both your hardware and your operating system and find a solution to the problem.
Turn your computer off and then clean your touchpad. Dampen a clean cloth with some isopropyl (rubbing) alcohol and then pat the pad dry with a paper towel. Even a small stain or sticky spot can throw off your touchpad's sensitivity, so it is vital that the pad remain clean of all extraneous substances. Re-calibrate your touchpad. Go to the hardware section of the "Mouse" utility (in the Control Panel) and find the device settings. There should be an "Advanced Settings" or "Calibration" utility under this tab. Follow the prompts to calibrate your touchpad for maximum efficiency. Use manual troubleshooting wizard. If you suspect that your computer's software or drivers are at fault, run the manual troubleshooting wizard. Go to the "Mouse" utility (in the Control Panel) and then go to the "Hardware" tab. Select your touchpad and then click on the "Troubleshoot..." button. Follow the prompts to troubleshoot software issues that could make your touchpad jumpy. Reduce cursor speed. In the "Mouse" utility, go to "Pointer options" and reduce the speed. This will prevent the cursor from going too fast when you move your finger on the touchpad, which could be the source of the "jumpy" effect.
Feb 15, 2013 | Toshiba Satellite Computers & Internet
My mouse does not works properly/ it works slow, cursor makes little jumps, movement not smooth. Laptop samsung R40
Are you using it on a mousepad? If not, that is probably why you are getting jumpy and erratic movement. Put a mousepad underneath the mouse and you should see the cursor movement improve.
You can also adjust the mouse properties such as speed and control by going into the Control Panel and opening the Mouse applet.
Do you have the correct Dynex driver installed? If not, go to the Dynex website and download the driver for your mouse. Having the wrong driver (or a generic driver) can make a difference in performance sometimes.
Hope one (or all) of those solutions helps!
Jul 08, 2010 | Dynex Wireless Optical Laptop Mouse...
My mouse optical mouse is "jumpy" as I try and move it across the screen. It is very annoying. The wheel works find its just trying to move the mouse around. I have trying fixing the pointer speed and...
Change battery. Uninstall the mouse software from the device manager. reboot and see if that doesn't help. If you have a setting problem, try finding HP mouse in the control panel and see if you can change the jumpy situation.
Jul 06, 2010 | HP Wireless Optical Mouse
My PilotMouse is getting jumpy and doesn't track well
Try updating the software for wireless mouse as a new update has been released. GO to apple sign, click on it, then go to software update. Install the updates required.
Advise if this fixes it.
Thanks
Apr 09, 2010 | Kensington Pilot 72239 Mouse
It is jumpy! It's very hard to point it to anything with any accuracy, as it jumps about, and isn't smooth.
All you need to do to fix this problem is get a mouse mat, or short term just a bit of paper. If the desk or table that you are using the mouse on is in any way shiny then the laser will reflect and will be jumpy
Mar 15, 2010 | Microsoft Wireless Laser Mouse 6000...
Erratic behavior of MS wireless optical mouse
Your wireless mouse the battery might be low, change the battery and go to control panel and click the mouse icon, and adjust the right mouse speed setting.
hh
Jul 27, 2009 | Computers & Internet
Intermittent problem: green usb and red light on mouse blink
After synchronizing connecting buttons, take off battery, look for a tiny thin button that protrudes in one of the sides where the receiver is placed in mouse, hold it depressed and then install a new and fresh battery releasing simultaneously said button. Hope you solve your problem. Good luck!!!Chawah.
Jul 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
Hyper senitive & erratic mouse
reinstall the driver for the mouse and see if that fixes it.... also you can try going to control panel----mouse and the changing the settings... you may have to experiment abit to get it the way you want it.
Robert
Please take a moment to rate this solution... thanks
May 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
Logitech 9311570403 Mouse Logo
376 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
