Question about Canon MultiPASS C80 All-In-One InkJet Printer
Need printer driver for XP XP2
Canon Multipass C80 can't communicate with computer - windows XP SP2. Canon doesn't have driver for this old type device.
  • Anonymous Sep 03, 2008
  • mashaban2 Sep 03, 2008
    I tried to install multipass c80 software version 2.0.6.0 on windows XP SP2 ,but I get this error (( this version of multipass suit will not install on microsoft windows 2000))
    please help
    Scholar:
  • 35 Answers
Ok. This is going to take a little patience and a little work so bear with me. First since there is no Windows XP driver for this device you will first have to install the available Windows 2000 driver. Go to this link to do so. http://software.canon-europe.com/software/0005192.asp?model= Next, you will need to run a Windows XP update patch to make the Windows 2000 driver work with your XP machine. You can get the update patch here.. http://software.canon-europe.com/software/0006655.asp?model= Be sure to read the XP_PatchInstallation.pdf file to make sure that you do everything in the proper order. After you have completed all the required steps, you should be able to use your C80 on your XP machine. Hope this helps. Good luck.
Posted on Jun 26, 2007
    Genius:
  • 2,985 Answers
Go to Printers/faxes Click on install printer When the Put in CD/or select from list comes up Select from list Select Canon on the left field Select Model on the Right field Click install/OK Job done. If USB make sure you select the USB printer port If Parallel select LPT1
Posted on Jun 22, 2007
Driver Canon Multipass L60 For Xp
According to Canon the Multipass L60 is not compatible with Windows 2000 or XP.
The trick is using the Multipass 6000 driver for windows 2000. This printer is compatible with the MPL60. You need to edit the driver-inifiles (both copies of mpmaster.ini). as follows:
[Setup]
ModelName=MultiPASS L60
SGModelName=Canon MultiPASS L60
BaseName=MultiPASS
PrinterName=Canon MultiPASS L60 Printer
Version=3.01
NTonly=1
[DeviceID]
MFG=Canon
MDL=MultiPASS L60
Please rate me
Nov 19, 2010 | Canon MultiPASS L60 Laser Printer
Tip
Installing canon mutipass F80 on windows xp
If you are having problem installing canon multipass F80 on windows xp, you are not alone. This is the process:
Power on the printer
Connect the US cable to the computer
Allow windows xp to find new hardware
choose the option that allows you to locate the driver
Point your computer to the location of the downloaded driver
choose windows2000xp
then allow windows to install the driver
After windows has finishing installing the driver, run set up again from the file you downloaded. You will be ok and ready to print.
on Mar 23, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Need a Canon Multipass L6000 driver
There are drivers available here for limited operating systems (Windows Me, 2000, NT, and XP).
Feb 25, 2010 | Canon MultiPASS L6000 All-In-One Laser...
Canon MultiPASS F60 failure to communicate
Go to this web site. In the search window in the center of the screen, type "windows xp drivers" and click on the Search button. Select the first answer that shows, and you will receive instructions for downloading and installing drivers which were developed for using the MultiPASS F60 with Windows XP SP2.
Sep 26, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon Multipass c20 driver for XP
MULTIPASS C20/C50 ON WINDOWS 2000/XP This device is not compatible with Windows 2000 and Windows XP as a multifunctional device. For this product, Canon advertises compatibility with the following operating systems: Windows 95, 98, Millennium Edition (Windows ME).
Printing functionality may be possible by following the steps below.
Step 1 – Install a compatible printer driver.
1. Start the ‘Add Printer Wizard’ from the Printers folder (Windows 2000) or the Printers and Faxes folder (Windows XP).
2. Ensure that the ‘Automatically detect my plug and play printer’ tick-box is not ticked. Press next.
3. When prompted, ensure the printer port is selected on to LPT1. Press Next
4. When the list of manufacturers and models is displayed, click on Canon, and then BJC4200. Press next until the installation is completed.
5. The printer driver should now be installed.
If you are using the BC22e photo cartridge, you will need to download the BJC4200 driver from the www.canon.com.au website.
Step 2 – Setting the Multipass machine to Printer Mode.
1. On the Multipass keypad, press Function, followed by 0.
2. Press the left arrow key until you see Dos Printing.
3. Press Start twice.
If you have successfully completed the above instructions, you may now find that you are able to print to the Multipass machine. To restore the Multipass back to its original mode, press Function, and then Printer Reset.
Feb 06, 2008 | Canon MultiPASS C20 InkJet Printer
Failure to Communicate
try re installing the drivers for this printer check all cable connections once again. did the printer work well at ur frens place? and wat os did he use??
Aug 29, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon MultiPASS C80 All-In-One InkJet Printer Logo
209 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
