Question about Eureka 4700A Maxima Bagless Upright Vacuum
How to change belt on Eureka maxima 4700a
I have a eureka maxima 4700a and the brush is not spinning. I believe the belt is broke, but it happened when my wife used it. I lost the manual, so how do I check and change the belt? Have no idea how to take it apart to do so. Thanks
  • cbogie Mar 04, 2009
    I believe the belt broke. There is a little window where you can see the dashed yellow lines. I can no longer see these. I can't find my manual, and there are no screws at the bottom of the vacuum or it looks like the top. I do see some screws in the back, but now can't find my screwdriver. Once I figure how to get this cover off, how do I change the belt?
Hey i had the same problem with mine, (standing over it and looking straight down) there should be two screws on the top of the yellow cover, one on each side, take those out and the yellow cover should easliy pop off. if the white ink is off the belt or the belt isnt tight than replace, once off just pop the wheel brush (which has the belt around it) up out of its socket and take off of the belt from the wheel brush and motor's metal pole, then put on the new one just like the old one was. let me know how it works out, redsox_belcher@yahoo.com
Posted on Feb 20, 2009
  • lighthousef2 Feb 04, 2011
    thanx..that was amazing it took me 5 mints to fix
  • Jim Jul 01, 2011
    Awesome! Thanks for this easy fix advice.
My girlfriend had the same problem. The brush stopped turning. I unscrewed the two screws on the top of the front yellow plate and it popped right off. The belt had snapped. Looks like an easy replacement. Seems like a cheap vacuum.
Posted on Apr 19, 2009
  • conneva Dec 09, 2010
    My Eureka Maxima 4704 had blue plastic housing so ours did not have a "yellow plate". However, once the two screws on top were removed I was eventually able remove the cover over the beater bar and belt, replace the broken belt and reassemble.
    Interesting that the manual provides step-by-steps on how to replace the bulb but mentions nothing about how to replace the belt.
    Habit-Forming:
    New Friend:
  • 20 Answers
You can purchase eureka replacement parts directly from Govacuum with an exclusive 11% discount for Fixya.com readers, use code: FIXYA11 at checkout to avail the offer. We also offer free shipping over $35.
Eureka Belt - https://www.govacuum.com/collections/vacuum-belts/eureka
Jeethu
Govacuum Team
Posted on Sep 17, 2017
The bearing has went out on mine -- look to see if the end "caps" on the beater bar are not ""lobsided" -- my bearings were out but it still lasted long enough that it was worth the price of the vacuum
Posted on Jul 14, 2012
I need to know what type of belt my Eureka Maxima vacuum takes.
The belt you need is one that fits the 4700 series or if you find any other Eureka packaging the belt would be the "U" series. You can find them at Wal-Mart.
Aug 13, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
How do I change the belt on Eureka 4704 and where do I get belts
you can get belts (quality for great price) from amazon, here: Amazon com Eureka 4700A belt.
Wish you best of luck.
Ryan
May 29, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
Belt is off
You need to replace the belt. Over time they stretch and wear and then don't stay on and make it so the vacuum doesn't pick up well. Here is the belt you need and a manual you can view which has instructions:
Eureka Maxima Belt and Manual
Feb 07, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
Beater bar not moving. Is there a belt? My mom sucked up a sock and didn't know. So she kept vacumming and then smelled something rubbery burning. And then we found the sock and cleared it. Then the beater...
The belt is broken or badly stretched and needs to be replaced. Here is a link to download a manual.
Look for the "Download Manual" on the right side of page. Scroll down towards bottom of page and you'll see how to open it up to change the belt.
Hope this helps.
http://www.azmanual.com/manual/16335/eureka-4700a-maxima-upright-vacuum-manual/
Aug 24, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Brush won't spin
likely the belt is pinched in the guide. try taking it out and re seating it
Aug 29, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka 4700a bagless vacuum
it's probably the lower tube that is plugged, disconnect the lower tube at the elbow, use a large pipe cleaner (bent at the end your pushing through, as to not puncture the tube itself.) it should emerge just behind the brush. check in and around the pipe cleaner for any debris.
Nov 18, 2007 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka 4700A Maxima Bagless Upright Vacuum Logo
7,596 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
