Question about Plumbing
''no water'' Recently we had a ''cold snap'' with bone chilling weather. When i woke up there was very little pressure in the pipes when the water was turned on. I turned all the faucets on hoping to prevent the pipes from freezing. About 5 minuits later there was no flow in the bathroom upstairs. shortly later all the faucets downstairs stopped working. About 6 hrs later there was a tiny stream of water that came out of all the faucets but only lasted for maybe 30 seconds and stopped again. This was about 30 hrs ago. Can not find a plumber for they are all busy. My question is 2 part.>>> We are on a well. How can i tell if it is frozen pipes or a problem with the well or the pump,fuse ,circuit breaker ,switch ect. I do not even know where the pump for the well is? And if i can find the pump what do i check? My plumbing experience is limited so i am hoping someone out there can walk me through the process of elimination before a plumber gets here and charges a hefty fee for something i could have fixed myself? Any plumbers out there with input would be much appreciated! Thanks......................
    Problem Solver:
  • 6 Answers
I too had the same problem as you with my pipes freezing, but my heat was the culprit. Basicly the problem was the same. I turned the water on in the sink and when the water thawed there the pump started and oh my god I had broken water pipes in the house under the counter, so I turned the main water valve off, or the pump from the breaker box for the well. The difference is that if you turn the well pump off then the water runs until the pressure goes down. If you turn the main water off it will stop sooner. I fixed the pipes under the sink and behind the dishwasher started to leak, Fixed that and again turned on the water again at the main valve. Ask where your main water lever is. My water started to run in the sink area, but the drains were frozen, I put a heater under the house and heated up the pvc pipe that was still frozen. Of course the toilet..... When it got alittle warmer and the heat on the pipe, things broke loose. The plumber was no where to be found because they were so busy, this worked for me and people had great ideas for me to try. When the water and the pump were turned back on all leaks were fixed and things are back to normal. I am now wiser...I hope this story helps somewhat.
Posted on Jan 18, 2009
I recently bought a fisher and paykel front loader washing machine and since it was installed it has created loud banging noises in my water pipes. Do you have any idea how I could fix this?
If you're willing to do plumbing work yourself, these and more will show you what to do.
Otherwise, a plumber will be needed to bring an end to the water hammer you are experiencing by installing an air dampener as shown below - kind of like a shock absorber on your car but in this case, the backlash of pressure is softened or eliminated by it or something similar.
Basically what's happening is the water valves are shutting off the water flow so fast, the water flow ends up vibrating the pipes and they bang against what they are next to.
Odds are you were experiencing it before but it wasn't bad enough to be noticed - I installed a set at my water heater and another set right before the water connections for the washer.
How to cure water hammer noise in your pipes
Noisy Water Pipe Hammering Tips Plumbing Maintenance and Repairs 25345028-0bjacsudnesclogzm4oikctc-3-0.png
Dec 30, 2014 | Fisher and Paykel Washing Machines
Changes in amount of water flow from shower head
when he soldered the connections on these pipes.. he may have partially blocked the flow with solder inside..if its restricted up to 50% then its a hell of a pressure loss..hot water is always lower in pressure anyway..also take the shower head and dunk in a clr solution it may have calcium deposits inside the small plastic orafices in it..
Jan 12, 2014 | Water Heaters
Why does my bathroom hot water pipe make several thumping noises and then quit when I turn on the faucet in cold weather but makes no noise in hot weather
It is called expansion and contraction...
When you turn the water on and off the pipe will move just a bit....
When the pipe is warmer it is a bit longer and it does not hit whatever is causing the thumping...
When the pipe is colder it shrinks just enough to hit....
This causes the thumping when cold...
It is not hurting anything... just annoying...
heatman101
Feb 12, 2011 | Plumbing
Cold water pressure poor in shower. Just had Rheem installed.
You might have clog in water lines.
If shower is only place where low pressure exists, then clog is probably at shower valve.
Disassemble valve and see if clog will flush out.
From there, you have to keep moving back along cold water line looking for pipe filled with sediment or elbow that has obstruction.
If pressure problem is bad at every cold tap, but doesn't affect Hot water, then clog is inside Cold line somewhere after water heater connects to cold line.
Buy a pressure gauge that connects to water hose.
Buy adapter that also fits pipe thread.
For example Brady BTG 100.
Test outdoor spigot for baseline pressure.
Open cold tap inside house and see how much pressure drops.
Close cold line and open hot tap and see how much pressure drops.
Next, move pressure gauge along cold water line.
Take apart pipes and inspect for obstruction at elbow or pipes filled with sediment.
Look for any place galvanized pipe connects to copper pipe, since this will be likely place for obstruction because of bi-metal corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pipes.
Jan 05, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have installed a Grundfos CH2050PT pressure booster system at my home (3 stories). The pumps is installed at ground level and is connected to the main water tank (source of water). The pressure is...
it could be the differential in pressure between the cold water from your booster pump and the hot water from your solar water heater . the cold water which feeds your solar heater is probably being reduced in pressure by a pressure reducing valve . so what you need is equal pressure on both your hot and cold water system you could install a pressure reducing valve on the pipe thart feeds your cold taps etc valve set at the same pressure as the one on the solar water heater that would give you a balanced hot and cold water system
Dec 07, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
It sounds as if it wants to start but will not. what could be the problem?
always have a fire extinguisher right there handy !! sound like no gas . change the fuel filter.. or carefully pore a small amount of gas in glass about a shot glas full and dump it in the air filter hose or TB and try starting it. SNAP OR PARTS MASTER CARB OR BREAK CLEANER IN THE SPRAY CAN WORKS WELL about a 3-4 second spray.. I DON'T LIKE STARTING FLUID IT CAN DAMAGE YOUR MOTOR, ITS MADE FOR BONE CHILLING WEATHER.. SPEAKING OF WITCH DO YOU HAVE THE RIGHT WEIGHT OIL ? IF ITS COLD AND THE OIL IS TO HEAVY ITS NOT GOING TO START . IT WILL TRY BUT GO. I HAVE SERVED MY TIME IN MINNESOTA . NOW IN FLORIDA I USED MOBILE ONE IN BOTH STATES AND FIND IT TO BE THE BEST TRY 5-20 MOBILE 1 OLDER CARS 15-50
Feb 14, 2010 | 1991 Mitsubishi Mighty Max
Our hot water in the kitchen froze due to -20 degree weather. When it came back on , we had very little pressure for the hot, but cold was normal. It has been this way for about 3 weeks now. Any...
Hello. When the pipe froze it may have dislodged a piece of scale or rust from inside the pipe. When the water flowed again the particle moved up to the small hole at the valve and caused a partial block. You'll have to shut off the water supply and disconnect the supply line on the hot side. You may be able to open the faucet and blow back through to try to remove the blockage. If this don't work remove the faucet handle and pull the cartdrige out to clean it. Remember to close the water supply.
builderdale
Jan 22, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Installing hot water heater
Do you have a valve somewhere in line that is not open all the way or worse broken. Shutoff valves can stick closed.
May 13, 2008 | Washing Machines
Plumbing Logo
344 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
