I have a 8100 series washer that creates to much lint on the clothes and i'm not shure if there is a filter for lint or how can i overcome the excess lint.
The Soloution is to remove the bowl and clean the slinger underneath the bowl.
there is also a build up of lint that stays in between the main bowl and the outer plastic bowl
this requires cleanining as well. in order to remove the bowl you wil need to do the folowin.
1. remove the two screws at the front that hold the control panel.
2.remove the two clips that hold the back cover fixed to the front lid and housing.
3.take away the front housing by tilting away from the controls.
4.remove the agitatator top plug by pulling upward.
5.there is a 7/16 hex head screw that needs to be removed here to remove the agitator.
6.remove the round lock nut from the bowl this can be a bit difficult depending on the corrosion of the nut, I had to make up a tube spanner to to remove the nut counter clockwise.
7. as you will se over the years there is a lot of build up.
hope this helps.
Chris Ficior.
Posted on Jan 19, 2009
Top load GE High Efficiency washer has been leaving excessive lint on dark clothing. How can I fix this problem?
Clean out filter also spin clothes in dryer the lint catcher in the dryer will catch the lint.
Nov 15, 2014 | Washing Machines
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Excessive lint on washed clothes
Your washer does not have a lint filter, so it's very important to sort lint givers from the lint takers. Washers today to not have lint filters because we rely on the dryer to remove lint that does not get pump out with the wash water.
Below are tips taken directly out of the user's manual:
  • Did you sort properly? Sort lint givers (towels, chenille) from lint takers (corduroy, synthetics). Also sort by color.
  • Did you overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely. Lint or powdered detergent can be trapped in the load if overloaded. Wash smaller loads.
  • Did you select the correct water level? The water level should be correct for the load size. The load should be under water.
  • Did you use enough detergent? Follow manufacturer's directions. Use enough detergent to hold the lint in the water.
  • Did you line dry your clothing? If so, you can expect some lint on the clothing. The air movement and tumbling of a dryer removes lint from the load.
  • Was paper or tissue left in the pockets?
  • Is your water colder than 60°F (15.6°C)? Wash water colder than 60°F (15.6°C) may not completely dissolve the detergent.
  • Did you use the proper cycle time and agitation speed for the load? Reducing wash time (duration) and agitation speed are ways to reduce lint.
Jan 10, 2011 | Maytag Atlantis MAV6000 Top Load Washer
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
Dec 05, 2010 | Maytag Washing Machines
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Clothes come out covered in lint after washing
Sears top load / direct drive washers don't have specific Lint Filters.
See the Use and Care manual for these washers for hints.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0705087.pdf
Apr 12, 2010 | Kenmore 24902 Top Load Washer
Maytag Legacy Series Washer. Lint settles on
Lint is in majority flushed out in drain cycle. make aire the tissue and match books aren't in any pockets. the lint is then deied and separated in the drier , Well so I was told . good luck
Jun 07, 2009 | Maytag Legacy Series Top Load Washer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Lint vent
There is no lint filter in this machine, however, the condensing duct and condensing bellows can get be a problem later on if it gets jammed up with too much lint.  If you notice that it takes 50% longer or more to dry your clothes, you will need to have the duct checked and cleared out of excess lint buildup inside.  Not an easy job but it can be done.
Nov 28, 2007 | LG WD-3243RHD Front Load Washer / Dryer
Excessive lint on clothes and smell
There is many solutions that work some. The best analogy I have seen is to reduce the wash time as the newer soaps are more efficient at removing dirt which also softens the fabric. Any excess in soap regardless of type in combination with water type will cause an odor, why is the contaminents in the water plus the junk on are clothes to be polite. It builds up under the basket and along the top water line in the tub plus creates a film from the tub through the hoses, pump and house drain. Lint is a product of excess washing and too much soap. Whirlpool stated for there front loaders no more than two TBL of liquid soap which is like 3/8 cup max for the old top loader. SearsTechToo
Apr 27, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
471 people viewed this question
Top Washing Machines Experts
