Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher leaves food particles on the dishes
It doesn't seem to clean very well. How can I tell if the spinner is turning?
  • 9 Answers
SOURCE: Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Posted on Jan 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: FOOD PARTICLES ON DISHES
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Posted on Mar 26, 2009
  • 112 Answers
SOURCE: New Amana dishwasher leaving (dried) food
CHECH YOUR DRAIN HOSE. IT SHOULD HAVE A HIGH POINT SO THE DRAIN CAN DORK PROPERLY. THE HOSE COULD BE TOO LOW UNDER THE SINK AND DRAINING BACK INTO YOUR DISH WASHER. OR YOUR GARBAGE DISPOSAL HOLE CAN BE CLOGGED
Posted on Oct 28, 2009
  • 198 Answers
SOURCE: dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Posted on Jan 02, 2010
heatman101
  • 43501 Answers
SOURCE: Particles of food on clean dishes
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 15, 2010
Dish washer is about four yrs old and is leaving dried particles all over dishes and glasses I have tried cleaning solutions and it still continues.
Either there is some error with the pump or the switching valve that switch the wahing water between the upper and the lower rotating water ejecting dishwasher arm. There is no longer water enough in the dishwasher to turn on both dishwasher arms at the same time. Had the same problem with a ASKO DW20.3. At the moment the ASKO is disassambled to change the motor driven valve. Kind regards. Henning
Mar 05, 2011 | GE Nautilus 24" Built-in Dishwasher
Hello, my 1992 GE potscrubber 630 is not cleaning well at the moment. Could vinegar or a little bleach help if it something is clogged with hardwater or food particles. thx.
My GE Potscrubber 630 dishwasher leaves a white film on all of the dishes. Is there a filter that can be cleaned out?
Aug 07, 2010 | GE Dishwashers
Soap (?) residue on dishes; also not getting them clean--food on
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
Broken plate in dish washer. Pump is now making noise. How to take pump out and clean?
at the bottom rear of the dishwasher there is a cover over the sump. remove this cover and below there should be water in the sump. feel down in this area and clean out the trash. there is also a metal cutter in this area that chops up small particles of food. you could have something in this area caught. be careful not to cut yourself.
Jul 18, 2010 | GE Nautilus 24" Built-in Dishwasher
Top shelf not cleaning
Hi, the most likely cause of this is the sump is plugged under the screen area, I have put some instructions together to show how to clean out down there. let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 28, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaves food particles on dishes
Jan 02, 2010 | GE Dishwashers
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Oct 20, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
149 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
