Question about JBL TLX PS10 Speaker
JBL TLX PS10 Subwoofer - Does not work
JBL TLX PS10 Subwoofer - Powered up, (Light on back is lit). Just stoped working one day.. No changes to wiring/power... I have checked wirring connects and replaced cable just incase. Funny thing is that Home Theater systems still recognizes there is a subwoofer connecet, (Shows Icon ), BUT no sound what so ever. When I take the RCA plubs out of the back no sound.. (usally you get a noise). Any suggestions on what next steps are ... Would liike to salvage it if possuible
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
If you have checked the fuses which it sounds like you have, your amp may be out. Take that RCA and plug it into the other speaker. If thar she blows, treat as warranty and call the factory. If this is helpful, please post as such.
Posted on Jan 18, 2009
Interested in your Infinity sub repair; could I send you some images to verify infinity TSS-1100 has no light, seems blown to me, not sure if it has the screw you mentioned
Hi my name is MIchael and I repair the following amps JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P. If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P - you will find us ... Edwards Electronics ....
Oct 24, 2011 | Infinity TSS-1100 System
I have a JBL TLX PS10 sub woofer, and it keeps blowing fuses almost immediately.What do you think the most likely problem is? also, where can I download a free service manual for this item? I have removed...
Edwards Electronics not only repairs the following amps they also do upgrades to them so they do not burn up again: TSS1100 TSS1200 PS10 PS12 E250P PS210 and a few others - Look on Google for them or Ebay. Thanks.
Aug 17, 2011 | JBL TLX PS10 Speaker
Hi, my E250P is experiencing blub, blub sound after 45 minutes to 1 hour in operation for the past few month. But at this point of time, when switch on, loud wobble sound are generated even the input...
WE REPAIR THESE AMPS ... JBL PB10, PB12 (IF SCREW NEAR ON/OFF SWITCH) WE REPAIR THE PS10, PS12, VENUE SUB12, TSS-1100 TSS-1200 E250P. CHECK FOR US ON EBAY EDWARDS ELECTRONICS OR MESASURPLUS.COM - FAST WORK - WITH WARRANTY - HAVE FIXED THOUSANDS OF THEM.
Mar 16, 2011 | JBL Northridge E 250P Subwoofer
I have a pair of JBL S412P speakers and the powered subwoofer just stops working and then a month or two later it starts working again and then goes out again. The lights on the bottom don't light when...
The fact that the LED's also go on/off points to a power supply fault.
First check the mains power plug for the power-pack, as if it's supplied by 2-pin 2 amp type, the adapter contacts could be loose.
If not this, or directly into speaker, check DC socket, or a cracked internal board track or dry solder-joint.
Jan 31, 2018 | JBL S412P Main / Stereo Speaker
I have an older JBL TLX PS10 sub woofer but hardly used. I get a green light when plugged in. However, the speak makes a loud continuous noise when I plug in the Y connector to the low level input. It...
Just touch your fingertip to the input connector on the sub -- similar noise? That would be its amp picking up the hum of the room through your antenna-like body. IF that is the same noise, you need to make sure your input cable is shielded and connected at both ends BEFORE applying power to the electronics at either end.
Be mindful of electronic noise sources such as track lighting, UV lights, motors, TV's, etc, and route the signal and power cables well away from them.
Try reversing the orientation of the AC plug at the sub and see if that helps out.
Feb 10, 2011 | JBL TLX PS10 Speaker
I have a powered sub woofer, i noticed it started to make scratching sound or popping, then i noticed it wasnt on and had a red light on the back instead of a green light. I turned it off for a hr and...
This item needs to be repaired - shorted or bad parts on board. See Ebay for Repair of JBL and Infinity Amps - Specific Models - Search - Be Happy:)
Jan 03, 2011 | JBL Venue SUB10 Subwoofer
Subwoofer
You have the subwoofer plugged into ac and you see a light? parhaps the RCA cord is bad. Try another one.
Jun 09, 2008 | Sony STR-DG800 Receiver
622 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
