Question about Crock Pots & Slow Cookers
Ultrex pressure cooker - don't know how it works - need manual
We were given model Ultrex 07714K (looks like fryer/cooker) & Ultrex
07708 (8 qt. cooker) -- they are like new, but no instructions. We don't know how much pressure these things hold -- there is a red button that pops up but don't know what/when. Is there a resource anywhere so we can use them?
  • 1 more comment
  • Anonymous Jan 20, 2009
    PLEASE....need instructions to use the same Ultrex Model 07714 Pressure Cooker. Brand New.....HELP!
  • gloria arnold Apr 27, 2009
    I also have an ULTREX model# 07714 K 6 qt. Pressure Cooker and I needan instruction manual and maybe a pressure regulator. It has oneremovable ring on the regulator and I think there is supposed to be 2. Please help!
  • dusty92 May 01, 2009
    need manual for 8 qt. ultrex pressure cooker
5 Suggested Answers
SOURCE: manttra 6 qt pressure cooker
try this link:
http://www.presto-net.com/products/manuals.php
Posted on Oct 27, 2007
SOURCE: Ultrex Slow Cooker
Anwser NO! My Roasting pan craked at 4OO degrees cooking a Chicken!
Posted on Dec 13, 2007
SOURCE: Lid to Ultrex slow cooker suddenly exploded in the sink
Why is it so hard to find where I can buy a replacement crock pot insert for my rival ScvP600. It has a crack in it. Is it like a timex, where I should just throw it all away after a few uses?
david@visualcourtroom.com
Posted on Dec 26, 2007
SOURCE: Bought a new Ultrex II 6-quart non-stick pressure cooker
I found numerous recipes on 'About.com' Type in the receipe that you are wanting and add pressure cooker to the search. I have also found recipes on other search engines.
Posted on Jan 28, 2009
  • 5 Answers
SOURCE: ultrex pressure cooker model innova 14240
Pressure cookers are only slightly more complicated than crock pots. In fact, you can think of them as the opposite of Crock pots. Where a crock pot needs 2-3 times as long to cook something, the pressure cooker needs only 1/2 to 1/3 of the time.
These are not that complicated and haven't changed in the last 50 years. The only real hard part is being sure is doesn't explode; not that hard: don't cook things that would foam, like pasta or potatoes. Just read some recipes on the internet or get a recipe book at a bookstore, used book store (super-cheap)or the library. My best advice is to make sure you use the lowest possible heat that still allows steam to escape at a whisper. That will keep things from burning (or scorching) on the bottom, which can give a harsh taste and make clean-up more work. Just do it.
Posted on Feb 21, 2009
I need control cord for ultrex electric pressure cooker
Check with an appliance parts stroe or on the internet.
Jan 12, 2015 | Ultrex Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    I need an instruction manual for a Cook's manual 8 qt. pressure cooker.
    Dawn, We're you able to find the Gasket you were looking for? I have the same 8 qt. manual pressure cooker, hard anodized, #Y22-4(8)-00 and am in need of a new gasket. Can you please advise?
    Jan 01, 2012 | Crock Pots & Slow Cookers
    Liner cracked. Can it be purchased from anywhere?
    Innova, Inc.
    P 800-767-5160
    F 913-541-8561
    info@innova-inc.com
    Ultrex Slowster 8 qt slow cooker 9 qt roaster Model 08393
    Sep 19, 2011 | Ultrex 2-in-1 (9qt) 8-Quart
    The recalled 8 qt ultrex ll pressure cooker model # 11302c will the lid come off on its own or does it just not lock while under pressure?
    Halt, do not use this pressure cook. The lid is suspose to lock. This means the lid become a dangerous fly object if it came off under pressure, plus extremely hot boiling water and the contents of the pressure cooker. Beside possible dying from the lid, and if one survives the flying lid, one will be will scalded by the contents of the pressure cooker. Another pressure cooker manufactured in China. Sorry, GB...stewbison
    Sep 12, 2011 | Ultrex 2-in-1 (9qt) 8-Quart
    Manual Wolfgang Puck #BPCR0005
    Here is the site for this pressure cooker and model # that you need...
    http://www.wpcookware.com/manuals.asp
    It's on the left hand side under the panini maker...the picture is of the 7.5 size but under that picture it does have a drop down menu that says model # and that 5 qt Pressure Cooker with that Model # is there...
    Good Luck
    Shelly
    Oct 12, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
    Dec 19, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Ultrex pressure cooker manual
    where do i get a tower pressure cooker manual from?
    Apr 21, 2008 | Crock Pots & Slow Cookers
    Crock Pots & Slow Cookers Logo
    1,041 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
