Question about JVC AV-27F802 27" TV
Blue screen appears instead of picture on TV
Power indicator light is now red, it used to be green.
Cable was loose under the house from the satellite system.
Posted on Jan 18, 2009
Screen black
Here's the test to determine which board is faulty. With the TV on, as usual, shine a flashlight on the screen to see if there is a faint picture. If there is, then the ballast board for the backlights is bad. If there is no visible picture, then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 13, 2017 | Hitachi P50H401 50 in. Plasma HDTV
My TV goes on and off on its own.
Bad light engine call Encompass Parts 1-800-639-3328
Feb 08, 2010 | Televison & Video
I RECENTLY PURCHASED A 1994 bIG SCREEN TV ( mODEL # TP55C81 ) THE PICTURE IS PURFECT BUT IM SEEING THE RED GREEN AND BLUE LIGHTS . THE CLOSER I AM TO THE TV THE SMALLER THE LIGHTS ARE AS I BACK UP THE...
You have a projection TV - basically a red, green, and blue spotlight is shown onto the back of an opaque screen that creates the color picture you see. The spotlights you are seeing is common for a TV of this vintage and type.
According to the user's manual, you should ideally be sitting no closer than 10 feet to the screen.
Sitting closer to the screen may enhance the phenomenon you are experiencing.
Nov 19, 2009 | Toshiba Televison & Video
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
The picture is only producing the basic colours red green and blue
Can you post a picture of the Tv with the issue stated?
Feb 28, 2007 | JVC AV-24F703 24" TV
TV won't turn on
The red light instead of green is an indication that theres a voltage missing or an improper voltage in the sweep or main power supplys. This should be handled by a trained service tech. Good Luck
May 28, 2006 | Durabrand DWT2704 TV
JVC AV-27F802 27" TV Logo
43 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
