Question about MegaVision MFV141 14" LCD Monitor
Turning red the blacks on my monitor are turning red, the screen saver is black is not totally red happened over 3 days,,, no computer infection, unplugged replugged, never touched adjustments
After many ideas, i asked a computer person an dthey sugessted that i try changing the monitor to another and see if it still happens, if it does its either your video card or your cables, so checking cables, pins and all i changed monitor and it didnt happen so my monitor is dying :( thanks anyays) j
Posted on Jan 18, 2009
My monitor occasionally blacks out. I turn just the monitor on -- wait a few minutes then it works ok for a while until it blacks out again
There are controls that turn off the monitor, both in Windows control panel and the monitor itself. The system should know if activity is happening, and should not blank if active.
Look at screen savers, too.
Jan 28, 2011 | HP w1907 LCD Monitor
Screen saver displaying unwanted message
This happens on monitors with a sleep type function. Make sure that the sleep mode is turned off and that it is set to never turn off inside of windows. Then the no signal error should not come on again.
Sep 07, 2009 | Computers & Internet
When PC is not used, screen goes black, then Check Signal Cable
right click on your desktop.go to properties.in properties go to the screen saver tab.click on the screen saver tab.under the screen saver tab you will a tab called power.click on power.change you monitor settings there.let me know if it works
Our monitor would work fine for a minute after it is turned on and then black out
you need to go to desktop and right click on a place where there is no icons. than go to properties. then go to screen saver. select power always on and this will stop this. also select no screen saver. good luck and good day
saw
Jul 06, 2009 | Proview Computers & Internet
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
My screen is blacking out without removal of power
Check the monitor settings - is the screen saver ON?
Jan 31, 2009 | Computers & Internet
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Dell AS501 flat screen monitor
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Feb 28, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor FP71E turns black
Your monitor rectifier is dead you need change transistors С5707 and check the Capasitor big one!!!!
Nov 29, 2007 | BenQ FP71E 17" LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
MegaVision MFV141 14" LCD Monitor Logo
94 people viewed this question
Top MegaVision Computers & Internet Experts
David Payne
David Payne
Are you a MegaVision Computer and Internet Expert? Answer questions, earn points and help others
