Question about Peavey Audio Players & Recorders
As soon as switch is turned on fuse is blown.
Fuse gets blown when amp is turned on. cannot seem to find any electrical problems with wiring inside the amp.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    I think Power Supply is fried so fuse is blow off again and again.
    This amp should be checked by qualified tech.
  • 11,896 Answers
Try to find a better ground wire and also make sure the fuse is in before it is turned on or it will blow
Posted on Jan 17, 2009
Bake element doesnt work everything else does
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
nuker100.jpg Use an old tooth brush to help clean off the grille area.
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
Sep 09, 2008 | Maytag MER5775Q Electric Kitchen Range
No dash lights or park lights/ tail lights. found the fuse that was blown # 14 its a 15 amp, put a new one in and it blew as soon as i turned on the lights, so i bought a new light switch for like 50...
As with any electrical problem where a fuse blows, you will have to trace the circuit to find the overload or short to ground. It could be any of the lamp sockets or in the wiring harness.
Jan 23, 2013 | 1992 Buick Park Avenue
Can a bad voltage regulator cause the main 30 amp fuse to blow?
Usually a bad regulator will only cause problems with charging...
Sounds like you've got a short somewhere in the wiring...I'd start by checking the ignition switch wiring and the connections going into the fuse box.
Mar 19, 2012 | kawasaki VN 1500 Vulcan Classic...
In the Comfort Zone CZ7007 is there a repaceable fuse & if so is it located above the thermostat inside the control panel cover and where can I find another. No heat from unit or lights in switch but
I''m replying almost a year later, but this may help others who are having this problem. There seem to be a lot of problems with the tip over switch in the Comfort Zone radiator heaters (this is the switch at the very top, inside the panel, above the thermostat). I had the same problem- no heat, switches weren't lighting up. I bypassed the tip over switch (we have never tipped over one of our radiator heaters, so it's not an issue) and connected the switch wires with a wire nut and then further secured the wire nut with electrical tape. Now the heater works as it should again.
Nov 25, 2011 | Comfort Zone CZ7007 Oil Filled Electric...
I have a duet electric dryer GEW9250 about 5 years old. It stopped working last week. The light inside works but nothing else (no control panel buttons or lights or the digital display). A repairman...
Hello there and thank you for choosing fixya
To tell you the truth i dont think the contrlole panel was the problem the control panel rarly goes out here is a list of the most common things that go out and are a lot more cheep to replace
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 05, 2011 | Whirlpool GEW9250 Electric Dryer
The fuse that connects my air conditioner and my blinker blows. Before I turn the air on or use the blinker. It just blows out as soon as a I put one in.
You replace a blown fuse only 1 time
If it blows a second time you know the
circuit with a problem,unless you have
no owners manual,then you buy one
Next, you get a wiring diagram & see what is
in that circuit & start testing
If you have no basic electricity knowledge
or no car experience, then you should be at
a repair shop, not here.
Jun 14, 2011 | 2000 Mercury Grand Marquis
Replaced A 60am Fuse ,Ran For Two Days. Car Died and now i have no electrial juice to the whole car. suspect fuseable link.
You may be correct about the fusible link. Replacing a blown fuse without finding and repairing the reason it blew only leads to more problems and possible severe damage to wiring harnesses. Fuses are NEVER the CAUSE of an electrical problem. Blown fuses are ALWAYS the RESULT of an electrical problem. I would recommend taking the vehicle to someone who has access to the wiring diagrams and the proper equipment necessary to repair your electrical system. A blown 60 Amp fuse is nothing to play with. That fuse gave up it's life to stop your vehicle from burning to the ground. Please don't make it die in vain...car fires are never pretty!
Jan 24, 2011 | 1992 Buick Regal
Dryer will not run at all. It seems to have power going to it though. Any thoughts?
If your dryer doesn't work at all, it could be because of problems with:
Door switch
Thermal fuse
Wiring
Jun 14, 2009 | Maytag Neptune MCE8000AY Electric Dryer
My Power Protector Light wont turn Green
switch off the amp then take off all the wires off including the speaker wire and then reconnect the wires on like before the problem is that the amp is on protection and if that dont work then get it repaired another thing is make sure ur amp fuses havent blown.
Nov 04, 2006 | Sony Xplod XM-554ZR Car Audio Amplifier
711 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
