Question about Cakewalk Music Creator 4
When I load up my beat & try 2 record, It stop by itself!!!!!!!!!
Yea.. when I record it stopd automatically and says "DROUPOUT" in red at the bottom of my screen!!!!! How can I record my vocal over a beat without this problem? and 2 also have the timing of my vocal perfect with the beat????? I NEED HELP ASAP!!!!!
  • 22 Answers
Tyke, This is likely an issue of your CPU. This usually happens when you don't have enuff horse power (if u will) in your system. Audio engines take a TON of power to run, and depending on your settings and where u have your latency buffer set- you can easily get drop out. You should definitely check this:
http://www.cakewalk.com/support/kb/kb2003175.asp
but u might wanna change u're latency buffer first. think about your cpu speed and what other programs are drawing power.
Posted on Mar 05, 2009
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Mar 23, 2014 | 2006 Hyundai Accent
What is Automated external defibrillator?
Wikipedia says: An automated external defibrillator (AED) is a portable electronic device that automatically diagnoses the potentially life threatening cardiac arrhythmias of ventricular fibrillation and ventricular tachycardia in a patient,[1] and is able to treat them through defibrillation, the application of electrical therapy which stops the arrhythmia, allowing the heart to reestablish an effective rhythm.
With simple audio and visual commands, AEDs are designed to be simple to use for the layman, and the use of AEDs is taught in many first aid, first responder, and basic life support (BLS) level cardiopulmonary resuscitation (CPR) classes.[2]
Apr 22, 2013 | Medical
Hi. My Philips CD Recorder CDR 785 stops and turn off when i try to recorder from spotify.
The Unit turns itself off automatically after a few (variable) time when simply reading a CD and also when burning, then after 1 or 2 seconds it turns on and goes automatically in stand by mode. Any solution? Thanks.
Mar 08, 2011 | Philips CDR785 3-Disc CD Recorder
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
I have 2 rings around the left top and bottom
It supposed to mean its over heating, but if its just turned on and its doing it its probably slowly progressing to The R.O.D or a lights out and it is the R.O.D
Instead of tampering with it and voiding warranty call
1-800-4MY-XBOX
and Get them to help you if you bought it within last 3 years you will get a free replacement once you send it in and a free month of xbox live
Jun 04, 2009 | Microsoft Xbox 360 Console
EVERYTHING YOU NEED IS IN MY LETTER BELOW.
1. On your remote, find the record mode button; it is near the bottom on the left side. This button sets
the recording speed for the DVR. Faster recording speeds provide higher quality recordings.
2. Look at the display on the front of the machine: it should say XP ( records 1 hour on the disc,)
SP ( 2 hours, ) LP ( 4 hours, ) or EP ( 6 hours. ) You can also set it to record 8 hours on a disc,
but the quality of the recording will be poor.
3 Press the record mode button until the screen displays the recording speed that you want.
4 Note: if the powers fails or the Machine is unplugged, the machine will automatically reset itself to
SP mode.
Apr 29, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Water line to dispenser makes it all the way to a
if your getting water up to the bottom of the door at that fitting, its frozen within the door itself..you might try , hitting it with a hair dryer, at the nozzle and also on the inside of freezer door at back side of the dispensor.( sure beats defrosting entire unit.) but yea def frozen within door itself
Mar 23, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Recording session stops itself
the camera has a anti drop protection and anti ground shooting try setting up at home inside first
Mar 07, 2007 | Toshiba GSC-R30 Camcorder
Cakewalk Music Creator 4 Logo
75 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
