Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD 533HD5 has pink screen
I took the back off to take a look. The Blue and Red lights are on but the Green is off...then flickers a bit then off again. That would explain why the picture is pinkish. Any suggestions on how to solve the problem?
    Sergeant:
  • 227 Answers
Sounds like the gun is trying to fire up but has internal problems. You may want to see if you want to tackle the job of changing it out. Check with MCM Electronics to see cost of a new gun. 1-800-543-4330 or www.mcmelectronics.com
Posted on Jan 18, 2009
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
How do i switch my sd-533hd5 to hdtv
the only way to do this is u most upgrade ur cable box to hd box then connected to a component with the color green blue and red on the back of ur tv
Nov 03, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 53in.the colors will divide into the blue green and red. then blow a fuse ?
from what i have had in the past was with this problem was convergence problems but it seems to be something originating from your main board.
Nov 06, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Turns on for less than a second. then shuts off
Unplug fo a .5 hour let it reset then see what happens when I got mine to fire up the blue side to side convergane wouldnt adjust GOOD LUCK
Jun 13, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-533hd5, STKs changed, getting blue screen but not pict
Did you have double image before changing the stk's ? If not then there was no need to change them.. Pioneers are known for bad solder connections especially in the power supply section.. suggest checking that when you changed the stk's that there are no solder bridges between the pins of either stk ICs
Dec 22, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pink Hue
it must be the problem of convergence in the tv.
for pictures on where is the convergence settings click on this given link.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
but if its the problem in convergence board then check out for this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
May 04, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Flashing Green
I would guess that your problem is similiar to mine but mine is with the color red. The CRT went out which is a 400 dollar part and who knows how hard to fix.
Nov 21, 2006 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
175 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
