Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Problem for Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater...
I ahve a rinnai enersaver
By ferdinand_un on Jan 17, 2009
i ahve a rinnai enersaver 1004f model gas heater and i recently noticed that after several minutes sometimes just 2 minutes, the heater stops giving heat and the number 14 shows from the small LED where the set timer and room temperature is situated
Solution #1
posted on Jan 17, 2009
Not Rated)
hawkins111
Rank: Guru
Rating: 89%, 34 votes
#14 is the code for over heat. Clean the circulating fan and blower blades. If there is anything on the top of the heater it need to go. Check the sides to make sure nothing is obstructing the air entering the back of the unit.
Tom Hawkins
hawkins111@gci.net
Was this helpful?
Yes
No
Popular Solutions for Rinnai RHFE-1004FA 38,400 BTU
Questions and Unsolved Problems for Rinnai RHFE-1004FA 38,400 BTU
Do you recommend Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas?
Answer
Answer
The thermostat seems off as we have the temperature set at 60 degrees and, although the room... (More)
Answer
what are the vertical, horizontal and front clearances for the exterior exhaust vent?
Answer
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however... (More)
Answer
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I... (More)
Answer
rinnai energysaver 1000ft I havent used it before - we just bought this house with it instaled. when... (More)
Describe your Heaters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in Newport, KY
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
