Question about Elna Sewing Machines
Pressure foot on Elna Diva
The pressure foot on the Diva does not come down firmly to hold the fabric. It comes down very slowly . The machine stitches perfectly if I hold the pressure foot down. My husband thinks it could bee a worn spring. If this is the problem, could you please advise what sort of spring it is, and how do we replace it. Thank you, Kaye
    Problem Solver:
  • 6 Answers
Make sure your presser foot is in the lower position. Open the door on the left and it has 3 settings. You may have moved it up for sewing something thick, and forgotten to lower it again. Sometimes things are simple, though your problem could be mechanical.
Posted on Oct 26, 2011
    Sergeant:
    Champion:
  • 334 Answers
You need to oil up by where the needle bar comes out of the top of the machine. Up on top there is a nut you tighten that goes around the needle bar this the way you adjust the pressure but the main problem with sewing machines is no one ever oils them and without oil it won't live God Bless Greg
Posted on Jan 18, 2009
ELNA 1000 not moving fabric through.
Have you got a tangle under your fabric? If so, release the fabric and rethread your machine, making sure the foot is up during threading. Otherwise check the feed dog under the foot. There's usually a switch somewhere that brings the feed dog up or down. If it's down the fabric won't feed. Another point, what type of fabric are you sewing. If it's leather or leatherette you'll need to use a roller foot. Hope this helps.
Oct 03, 2017 | Elna Sewing Machines
Elna 5200Q The material is bunching up in front of the feed dogs
Are the feed dogs actually raising, moving, and dropping (raise the presser foot and hand-rotate the handwheel and watch how the feed dogs are moving)? If not, check to see if the stitch length is set well above the zero (which means it sews in place)? Perhaps the presser foot pressure is set too firm and is preventing the fabric from moving under the foot.
May 17, 2017 | Elna Sewing Machines
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
Feed dogs will not move fabric
So right! You are brilliant!
Jul 03, 2015 | Sewing Machines
Why won't my Elna SU model 62c feed fabric?
thread looping on the underside is a symptom of no tension on the top thread so you need to look at the top threading path and the tension dial, is it set to 5? and is the thread pulled fully into the tension disc? Also always thread the top thread with the presser foot raised as this opens up the tension discs so the thread can bed in correctly. If you can see the feed dogs rising up and down above the needle plate during their cycle then they should be gripping and moving the fabric forward. Is there presser foot coming down firmly onto the fabric when you release the presser foot bar? This part does have a big spring inside which applies pressure downwards, maybe this is what the mechanic meant was broken. Was he a sewing machine technician? Maybe try to locate an old school Elna technician, start with www.elna.com and go to your country, then search for a local dealer.
May 25, 2014 | Elna Sewing Machines
I have an Elna Diva. I am trying to sew fabric with a waterproof rubberized backing and my machine skips more stitches than it sews. How do I fix this?
Because you have a rubberized backing the fabric is very tight and a loop cannot be formed properly, try using a leather needle
Oct 21, 2013 | Elna Sewing Machines
What is pressure foot on sewing machine. where is pressure foot
This is the foot that comes down and holds the fabric layers under the needle.
There will be a pressure foot lever to raise and lower the pressure foot at the back of the sewing area, it usually operates vertically, although some makes have a lever that works horizontally.
The pressure foot needs to be lowered BEFORE you start stitching as it activates the top tension and also helps with the stitch formation by holding the fabric firmly as the needle moves up and down.
You can read some general sewing machine info at www.sewing.about.com too.
Mar 29, 2011 | Janome Harmony 2039 Mechanical Sewing...
I purchased an Elna 7000 on E-Bay.Wonderful machine. I also purchased a 492000-20 walking foot for it. I can not find instructions on how to attach the walking foot to the machine.
I'm assuming that this is a generic style walking foot for low shank machines and it will fit your Elna?
To attach it, you will see a long lever arm at the front of the foot and the little curved bracket at the back of the foot.
Remove your usual foot and the clip on foot holder by undoing the thumb screw. Now fit the walking foot on instead by putting the lever arm around the needle bar and the curved bracket around the pressure bar and then putting the thumb screw back into place and screw up tight to hold the foot in place. Now lower the pressure foot and manually wind your machine forward a few stitches. As the needle bar goes up and down, it should move the long lever arm too which works the walking foot teeth gripping the top layer of fabric with each stitch.
Trust this helps.
Mar 24, 2011 | Elna 8007
GOOD DAY, THE ELNA 9000 WHICH I HAVE JUST BOUGHT 2ND HAND HAS A PROBLEM WITH THE PRESSSURE FOOT HANDLE. IT DOES NOT STAY IN PLACE, BUT KEEPS ON FALLING DOWN, AS IF A SPRING IS WORN OUT AND THE COTTON MAKES...
No pressure being applied to the pressure foot and therefore the fabric between it and the feed dogs means no feeding of the fabric.
The pressure foot has a spring up inside the head of the machine and this is probably broken causing this fault.
I would suggest that you take the machine to your local SM service technician..
Jan 28, 2011 | Elna 1010
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
176 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
