Question about Sharp R-1505 Microwave Oven
Sharp 1505 Microwave Display Failure
All functions work except the display first partially failed and now completely. Is there a single part that runs the display such as the display itself or display driver that has failed? How grievous is it to replace?
  • Sharp Master
  • 9,098 Answers
There are two options for this model:
- You can order our exclusive modified control unit (CU150) with our proprietary upgrades for $95, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $40. Details are here.
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
We have the service manual for this model and have uploaded it to our site here to help you.
Repair service details are here.
Posted on Jan 18, 2009
The display on our Sharp Microwave oven went very dim. Everything else on it is still functioning perfectly. Will replacing part FPNLCB666WRKZ fix it? Is this something we can safely do ourselves?
not familiar with that exact model .if the display went gradually dim and has a green vacuum florescent display ,these suffer 3 problems ,worn out display ;glass on display and filter window dirty ;and failed capacitors,suggest before replacing module ,unplug and put plug iside door ,then safely remove the back then take photo of display panel wireing then remove it clean inside the plastic eindow of display and display tube glass window .visual look at pcb you will see several round blue capacitors .note the values and voltage of these i.e 470u/25v. go to maplin and obtain replacements ,yhen get a friend who can solder to replace them all making sure to mark pcb with black marker ajacent black negative line on capacitors to ensure correct polarity then refit pannel and test .if no improcement replace complete panell
Dec 28, 2015 | Sharp R-314FS Microwave Oven
WMG30GS Whirlpool microwave display
please follow this steps and fix it. God bless you
  1. Main control board If the display on your microwave has gone out completely this is usually a sign that it is a malfunctioned main control board. To correct the issue the main control board would need to be replaced.
  2. Display board A display board can either malfunction completely or partially, causing two separate results. If the display on the unit has completely gone out, this can be attributed to either a bad main control board or display board. On the other hand, if the display has only partially gone out, this is usually a sign that the display board is defective and will need to be replaced
Nov 27, 2013 | Microwave Ovens
Sharp r-1505 microwave. several segments in digital display do not illuminate.
Sharp had "issues" with that board (connector cable fail). That was back in 2002. Give them a call and see if they will send you a new control board (part # CPWBF070MRU0) All of the 0's are zeros.
If not, look at that ribbon connector where it's kinked, and you'll see a spot that should be repaired, ie broken wire.
Good luck with the phone call. Refer them to bulletin # MW-166.
fil
Mar 01, 2011 | Sharp R-1505 Microwave Oven
My Sharp R1505 Microwave's LED display is malfunctioning, with only minimal lighting of digital/number segments. Do I need to replace the entire control board with a new LED attached or can I just replace...
You can order a new control unit (part number CPWBFB075MRU0 which comes with a display) from Encompass here.
Or you can get yours repaired for $39.95. Details here.
Feb 10, 2011 | Sharp R-1505 Microwave Oven
Microwave display flashing & beeping.
You have a failed membrane keypad.
On this model, GE doesn't make any parts available except the tray and the roller.
If it's in warranty, they will exchange or repair it.
It it's out of warranty, you're out of luck.
I'd advise you to contact GE Customer Service in case they may be able to help you.
Jul 25, 2010 | GE JES1036PWF 1100 Watts Microwave Oven
Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | Sharp Microwave Ovens
Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
Aug 13, 2008 | Sharp R-420DK Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
I would first suggest that you be sure every single wire got reconnected where it belongs.
Here is a diagram: http://www.microwavedisplay.com/r1500_series_wiring.pdf
If you still have toruble, see http://www.microwavedisplay.com
Nov 28, 2007 | Sharp R-1505 Microwave Oven
LCD Display failing
This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to disassemble it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 08, 2007 | Sharp R-1505 Microwave Oven
Microwave Ovens Logo
429 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
