Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
Snowblower acts like it is running out of gas
I have a craftsman snowblower. It will run fine for a while and then it will act like it is running out of gas and quit even though i have plenty of gas. Once it quits it will usually start back up and then die again. Occasionally, when I try to restart it, I get a flame that comes out of the muffler.
  • frybellevue Jan 18, 2009
    my snowblower runs till it warms up the n shuts off. if you pump the primer it will start and run for about 5-10 seconds and shut off again.
  • 513 Answers
SOURCE: 19.5 Briggs & Stratton dies while mowing
the engine is getting to hot or the oil level is to low check to make sure the engine is getting the air that it needs while running they have air vents in hood as well as on sides of most of those tractors or i would mow for a while & put in a cool place to cool down if i can further help e-mail me wade at
Posted on Jun 28, 2009
  • 13 Answers
SOURCE: Starts up fine then dies when hot
your automatic choke is defalting
Posted on Jul 21, 2009
  • 39 Answers
SOURCE: It Starts and runs fine for about 15 minutes then
Chances are the gas vent (or gas cap vent, as the case may be) or air or gas filter are clogged or dirty. replacing and/or cleaning them should take care of the prob.
Posted on Jul 28, 2009
  • 95 Answers
SOURCE: mower dies after running for a few minutes
It sounds like the carburetor is running out of fuel.First make sure the tank is full then loosen or remove the gas cap when it starts sputtering to see if that corrects the problem. Then with engine off remove the fuel line that goes from the tank to the fuel pump,hold it low and see if any fuel flows out of it,if not lightly blow air backwards to the tank,(with fuel cap off),then see if the line is plugged. Next remove the fuel line that goes to carburetor from the fuel pump,crank the engine and see if any fuel flows,if so the carburetor should be cleaned by removing it and disassembling it.
Posted on Aug 09, 2009
  • 12744 Answers
SOURCE: 17 hp kohler that is dumping gas out the muffler
carb float sticking open dumping gas into cylinders
Posted on Oct 19, 2009
I have 15.5hp Kohler engine on my Craftsman mower. After running for awhile, acts like it is out of gas, backfires and acts like it is going to die. Without the hood on it runs longer
sounds like it is over heating or boiling the fuel. take the metal engine covers off and clean the air vents out real good. blow out with air hose. put covers back on. move the fuel line where the most air is hitting it from the engine. be sure the fuel cap is good.
Jun 14, 2017 | Craftsman Garden
Craftsman 18" chain saw 42cc. Starts and runs fine. Will not idle after running for a while. Will not restart when hot. Will start after the saw cools down.
I had a 2 cycle snow thrower that acted similarly. It needed a new diaphragm. When they get old they act up. I could never see a physical difference between the good and bad one but the new one fixed it. It's a flat rubber part that is in the carburetor. Call Sears parts or visit them on-line to get a parts breakdown of the carb.
Feb 22, 2015 | Craftsman Garden
Snowblower acts like it is getting too much gas and not enough air, what should I do/check
check the float level
if getting too much gas it will run out the end of carb
adjust high speed needle , some dont have these any more
make sure choke is open all the way
Feb 02, 2015 | Garden
Craftsman snowblower will not kick over
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
Nov 21, 2013 | Craftsman Snow Blower / Snowblower Bottom...
Runs for about an hour then just dies and won't start.
run it with the gas cap loose the vent on it might be plugged
Sep 24, 2012 | Craftsman Garden
Truck acts like it is running out of gas? Replaced fuel filter. Ran fine for awhile but now still acts like it is starving for fuel.
my '93 f-250 (4.9L) stopped running while driving, now it acts like it isn't getting any fuel. Tried switching tanks, but still does the same. What would be the problem.
Aug 17, 2010 | 1993 Ford F250
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
Craftsman 8hp snowblower starts but will not stay running.craftsman 8hp electric start dual stage modle 536881800 snow thrower
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Dec 19, 2009 | Garden
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
371 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
