Question about HP PSC 1210 All-In-One InkJet Printer
Double Blurry Print
When printing, some lines are blurred, with double print, some lines are darker printed than the next line. Is something not lined up properly. The printer is a Kodak ESP 7 hooked up to a HP computer.
    Novelist:
    Sniper:
  • 68 Answers
Usually hairs sticking to the underside of the print head causes this.
I gave a solution to an Epson CX6400 user who needed to physically clean his print head. Look this up in the solutions. It involves using folded kitchen roll under the print head with the printer switched off and the head unlocked and free floating.
It would take me ages to type this again so please look this up.
The user had jammed paper and cleared the jam but had paper stuch to the underside of his print head.
I hope this helps.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Posted on Jan 17, 2009
Just replaced all of the print cartridges. Now print is blurry looks like double print
First perform ink head cleaning a couple of times as follows. 1)Press Ink, 2)Press arrows to choose cleaning and press OK, 3)Press arrows to choose all and press OK. Do this a couple of times. Then you can perform check print quality as follows. 1)Press ink, 2)Press arrows to choose Test print and press OK, 3)Press arrows and choose print quality and press OK, 4)Press color start. the machine will print a chart. Inspect the short lines on the four color blocks If any are missing follow on screen instructions.
Feb 19, 2014 | Brother MFC 6490CW InkJet Printer
Epson workforce 600 blurry 5th line
Update: Blurring of every 5th line occurs in text mode but not text & image mode. Know of a way to see text & image as default for all print jobs?
Aug 18, 2012 | Epson WorkForce 600 All-In-One InkJet...
Canon Pixma MP490 illegible
if there is enough ink , print a test page if same problem is there check printer's setting ..
or re-install the printer ,ah sometimes the files are encrypted wen u print it will not be print out properly...
Nov 29, 2011 | Canon Office Equipment & Supplies
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Double printing sometimes-HP DesignJet 500-800 series
When was the last time the heads were aligned? If that's not it, it's the belt.
Dec 17, 2009 | HP Office Equipment & Supplies
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
Dark Blurry Ink Line
When I print darker color images I get what I call Zebra stripes across the picture on a slant about 1/2 inch apart. Changed the toner and the drums are at 45% capacity. Any suggestions. Thank you.
Sep 03, 2008 | Konica Minolta magicolor 7450 Laser...
Print result at 1st line ok..2nd line become blur..its alternate till end of printing
Replace the ink cartridge.
The cartridge is so wide that it can print 2 lines at a time, and the upper part of it is probably partially clogged. That's why every 2'nd line is blurred, and the rest is ok.
Jan 17, 2008 | Office Equipment & Supplies
Double printing
This one is too lenghty to give you here, goto lexmark.com, and in support knowledge base, search with this line...blurry, fuzzy, or double print from a lexmark x4720...There is specific info on test pages you need to run to narrow this down.
It could even be a conflict with motherboard/proccessor that can occur with some e-machines, compacs and others using certain amd chipsets
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
331 people viewed this question
Ben Johnson
