Question about Dryers
Dryer making chirping noise while drying.
While using the dryer it is making a very loud chirping noise, regardless of how much we are drying. It happens about 60% of the time and is sometimes louder than others. What is this and how can we fix it?
Thanks!
  • Dryers Master
  • 8,220 Answers
If this is a GE/Hotpoint dryer then I can tell you exactly what it is. The rear drum bearing is worn down. WE3X75. To replace it you must remove the drum. This involves opening the door and removing all screws holding down the top. Then removing those holding the front on. Then removing the drum itself. This is not a hard job for a mechanically inclined indiviual.dryer making chirping noise while drying. - 389d186.jpg
Posted on Jan 18, 2009
Everything is fine, except it chirps. Chirps loudly and goes for a while, stops chirping, then starts chirping. Is there a drive belt that needs lubricating?
Hi Ron. I just lost a very extensive reply to you. Yes it can be the pulley making the chirp or the drum rollers. Items 15 - 18 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5172907&diagram_id=1356738#d1356738
It can also be caused by dry drum rollers but usually this is associated with a rumble: Items 2, 11, 12 and 13.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5172907&diagram_id=1338080#d1338080
Thanks for choosing FixYa.
Kelly
Aug 17, 2010 | Maytag SDG3606A Gas Dryer
My GE DBXR453GAWW is making a loud chirping noise
The rear drum berring is worn causing the chirp.
The motor berring is bad causing the chirp.
Service is needed to prevent fruther damage.
Jan 19, 2010 | Dryers
Maytag Neptune Dryer makes loud noise while drying.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
GE Electric Dryer DBXR463EG0WW making loud griding noise when on
heatman101
Feb 22, 2009 | GE DBSR453EBWW Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
A hard plastic liner from my front loader dryer has broken off and now the dryer makes a loud noise when drying.
This sounds like one of the drum front plastic bearings has come out or broken, there can be as many as 4 or more of these bearings depending on make, you would need to replace all bearings regardless off wear.
Again, depending on make, this can be quite a job to do ,and on some makes it involves a strip down.Plz rate my solution.
Thanks.
Dec 29, 2008 | Dryers
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Dryers Logo
473 people viewed this question
Top Dryers Experts
