Question about Garmin StreetPilot c550 GPS Receiver
My garmin Street Pilot just went dead on me.
I took apart the unit to find the Lithium battery. However I saw nothing that looked like a battery. There was this long tube like piece that went from both ends of the speakers. this tube like thing is screwed down. is this the battery? I thought that these batteries were metal batteries. If not can anyone show what the battery looks like for this unit. Normally I don't get extended service plans & since I didn't get one I'm reall ********** about it
Thank you for your help in advance
Mark
I got back into my vehicle today to go get my mom at the airport. I plugged the unit In & It worked. I suspect that It is the battery. After I shut off the engine I got the message that says do you want to still operate on battery power. I clicked ok but it said low battery. So now I have it charging by using my portable air compressor. So hopefully It doesn't die on me for at least another few years or if It does then It's time to upgrade to the Nuvii
Thanks for the people that replied to my question.
firehalt
Posted on Jan 18, 2009
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
How do I change the batter in a Garmin Street
Hi! You may need to change the fuse periodically, which is at the tip of the adopter! regarding battery, you may need to contact waste disposal section for disposing the unit since it contains lithium. Don't consider much presence of high amount heat and direct sun rays at new battery for longer duration and have fine
Dec 21, 2009 | Garmin StreetPilot C330 GPS Receiver
How do you change lithium ion battery in garmin streetpilot c530
The unit can be opened by removing the frame around the screen. However if you are still under warranty you will void it. The battery is not an easily replaceable one since it is soldered into the unit but if you are hany with a soldering iron it is fairly straightforward. However you have to find the correct battery which you can do with an online search.
Nov 01, 2009 | Garmin StreetPilot C330 GPS Receiver
My StreetPilot C330 can't turn on My gps stay close, i can't use it anymore
Your 'custom' lithium battery died. You can try getting a replacement from the internet, but be aware that the battery is not a simple 'plug-n-play'. There are leads that need to be soldered. Then there's the matter of re-initializing the unit. It may or may not work when you do a system reset.
Your best bet is to 'bite-the-bullet' and contact Garmin tech support for an RMA. They'll charge $79 to repair/replace this model.
This situation is common among GPS manufacturers on lower-end units. Best Buy showed me that there are some new units out there (over $500 ) that do have disposable batteries where its easy to change.
Jul 25, 2009 | Garmin StreetPilot C330 GPS Receiver
Help me unlock my gps i do not remember my pin # all i can remember is there is 6 # in the pin please help me
Take it back to the 'secure location' as indicated in your service manual. It will automatically unlock when it gets a full satellite signal. You have to enter the PIN number twice when setting up the unit. You should always use a number which is familiar to you so you can remember it. If you can't remember it, and if your secure location doesn't unlock the unit, you will need to send the unit to Garmin to unlock it. You will need your receipt for Garmin to unlock the unit.
May 31, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin Street Pilot C550 went dead
Did you try reset button? There's also a 2 amp fuse in the cigarette lighter plug in charger. If it's blown and battery is dead unit won't work.
Jan 17, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Street pilot
There is a reset button on the unit
Aug 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Street Pilot 330 battery dead?
it would be strange for the lithium ion battery to be dead so soon. what have you done to charge it up? there are ways to kick start the batterys but i need to know a little history on what has occured up to now.
Jul 05, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
