Question about Kenmore 15899 Built-in Dishwasher
Dishwasher tub leaks underneath
I have a 5-8 year old Kenmore dishwasher that is now leaking underneath. It is a slow, steady drip when the unit has water in the bottom of the inside tub.
I got underneath with a flashlight and mirror and found a 1/8 - 1/4 inch crack in the tub. My questions are: Would repairing it with JB Weld work? Could the crack be old and now water is somehow getting in between the tub walls and now leaking? There is no hole inside of the tub. I was thinking water could be getting in around the sump seal or something now and coming out of an existing crack. Thanks for any suggestions.
  • Kevin Moore
    Kevin Moore Jan 18, 2009
    Thanks for the response. All I have to do is put about a 1/4 of inch of water inside the tub and the leak starts. Doesn't have to be on. Ugh. Nothing's easy. I'll have to pull it out, tip it over, apply the patch and then say a prayer. Might just roll it out to the curb. ;-)
  • 344 Answers
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Posted on Jan 18, 2009
SOURCE:
Kenmore dishwasher noise
Sounds like the bearings of your motor are going out (wearing out). Check under your dishwasher for leaks during operation - if your bearings are going out, you will probably see some water dripping from underneath the dishwasher.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 03, 2012 | Kenmore 24 in. 16582 Built-in Dishwasher
Kenmore 665.16039403 leaks water when filling
It is coming from the fill tube. You can pull the unit out or use a mirror to look up underneath. It might have come off or got a hole chewed in it.
Eric
Sep 25, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Danby dishwasher leaking from underneath
It is still under warantee-contact the company you bought it from. If you fix it yourself you could void the warantee.
Jun 14, 2009 | Danby 22 in. DDW399 Free-standing...
Maytag MDBH950AWB Leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
zgwerty
Feb 23, 2009 | Maytag 24 in. MDBH950AW Built-in...
Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Nov 11, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Water leak
Mine also started leaking. Element also too hot. Mine has a 20 year warrenty on the tub (which I was NOT aware of) Repairman came today and the whole tub unit and element will be fixed for free! Look in your whirlpool instruction book to see if yours is warrentied. BTW, my dishwasher is only three years old.
Aug 21, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Leak off pump housing
Sidewinder, sounds like it's leaking from the pump gasket or the water seal assy on the impeller. Check the locking ring to the pump housing and see if you can increse the pressure to the tub. Also check the tightness of the motor fan assy. to the impeller assy. tighten if necessary. Pump gasket part number is 912529. Impeller seal part number is 903494. Catriver..post back.
Oct 23, 2006 | Jenn-Air 24 in. DW731 Built-in Dishwasher
Kenmore 15899 Built-in Dishwasher Logo
1,271 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
