Question about Hitachi 53UWX10B 53" Rear Projection Television
Blurred picture, colors not aligning.
Picture is blurred like others have written in. Colors not lining up and the magic focus does not take care of the problem.
    Genius:
  • 1,139 Answers
Hello mekysor,
You have a convergence amplifier problem. This is a common problem in these types of televisions. The fix for this problem is to replace the two convergence amplifiers in your tv. These amplifiers usually go bad along with the associated bias resistors. I would suggest that if you are going to do this yourself you should use only the manufacture recommended replacement parts. There are many who will tell you to upgrade the amplifiers, but my experiences have told me this is more trouble then it is worth, if you don't plan on redesigning the circuit itself. So with that being said, here is the basic procedure:
1) Get a schematic for your set (to be used in parts location and alignment instruction)
2) Using the Schematic locate the STK329-xxx or STK392-xxx series amplifiers (They are the two large six sided components attached to a large heat sink on the deflection board)
3) unplug the TV set
4) remove the deflection board from the TV set
5) using a soldering gun or iron with either a de-soldering pump or de-soldering braid remove the solder from the pins of the amplifiers and the associative biasing resistors.
6) remove the amplifiers from the heat sink and clean the heat sink off with alcohol or a solvent designed for removing the silicon paste.
7) coat the metal plate of the new amplifiers with heat sink paste and install them on to the heat sink.
8) install the associative biasing resistors
9) solder all of the components, making sure not to create solder bridges (short circuits) on the printed circuit board.
10) inspect the soldering job for bridges and cold solder joints (touching the joins up if they are cold)
11) reinstall the board to the television (reconnecting all cables removed.
12) power up the TV and perform the alignment instructions in the schematic
13) set the alignment of the TV
14) perform the magic focus setup
This should complete this task.
Now if you feel that you can not do these tasks, please consult a qualified TV technician about doing this for you.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 19, 2009
I have a 65 inch Hitachi projection TV and all of a sudden lines apperaed on the screen that runs across the upper part of screen. I tried using the"Magic Focus" setting to get rid of these lines...
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 24, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
Won't magic focus
Magic FOCUS button no help all?The tv have a problems known as a convergence problems,it dead 100%.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors it dead too.These parts on the tv convergence board must be replaced to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Dec 08, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I HAVE A HITACHI 53WX10B TV AND THE SCREEN IS BLURRED. I HAVE TRIED THE MAGIC FOCUS BUTTON AND THE SHARPNESS BUTTON. ANY OTHER IDEAS?
Magic focus button don't work or datas never reaches 100%.Tv have a problems,known as a convergence problems,it dead.Tv have colors lines R,G,B mis alingments,have colors shadows pictures or a 3D pictures look alike?The tv have a dead convergence board.The tv convergence board have 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost like $300-350 for parts and labors.
Dec 04, 2010 | Hitachi 53SWX10B 53" Rear Projection...
The magic focus does'nt seem to reset the auto convergence on the tv. Do you have any sugestions
The Magic focus button,not in effective anymore.The tv is 100% have convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 07, 2010 | Hitachi 46F500 46" Rear Projection...
The top of the screen is yellow color then drops down in a swoop and more yellow and blue. otherwise picture is good, pushed the magic focus but it did no good. thanks for any help
The magic focus button don't work.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Oct 13, 2010 | Hitachi 51F500 51" Rear Projection...
Can't get full screen. tried all aspect selections. also color is off. can't get it to adjust. magic focus dosen't help. any suggestions?
Magic focus button don't work.Colors lines R,G,B mis alignment,have colors shadows picture or 3D pictures.The tv have a problems known as a convergence problems,it dead.The tv convergence board it dead,must require replacing 2 STK convergence ICS and some or all it resistors to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 07, 2010 | Hitachi 57F510 57" Rear Projection...
I need to line up my colors and magic focus does not work.
If picture looks 3d in some way you have a convergence problem.
This set should use two of the STK-392-150 CHIPS FOR THIS.
The repair can be a do it yourself one if you have some skill. Magic focus only attempts to adjust at about 18 points on the screen.
Parts cost will be under 25 dollars. The repair consists of getting at the chips (2) and replacing both--on EBAY they will cost under 15 dollars (I fix sets and use a seller there).
If I can help make a comment here and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 15, 2010 | Hitachi 51F500 51" Rear Projection...
Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Oct 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Model 53fdx20bv2f012705
I have the exact same problem.......you just explained it a hell of a lot better than me. In the magic focus was red broken up, blurred and flashing as well as only 3 bars???
If you solved your problem could you please get back to me.
Thank you
Randy
gardner7768@msn.com
Apr 16, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53UWX10B 53" Rear Projection Television Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
