Question about Ricoh Aficio 1027 All-In-One Laser Printer
How do I fill developer and initialize
I am having porblem with the initial filling of the developer and initializing the drum
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
You must replace the whole Photoconductor unit, Type 1027.
This unit includes drum and also developer.
Then switch on the machine and it is initialized automatically.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
How quarts of Trans Fluid will fill the transmission???
Chevvy Malibu
CAPACITIES: Engine, with filter..........5 quarts [1]
Cooling System, Initial Fill..........7.5 quarts
Passenger Car & Light Truck Antifreeze & Coolant
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 6T40 Initial Fill..........6.3 quarts
Automatic Transmission, 6T70 Initial Fill..........6.3 quarts
Automatic Transmission, Total Fill
6 speed 6T40..........9 quarts
6 speed 6T70..........9.5 quarts
[1] After refill check oil level.
May 04, 2016 | Cars & Trucks
Need recommended Fluid specs and amounts to change oil for 1996 Toyota Tacoma 4 wheel drive front and rear axles
Hello there,
From this page https://www.worldsbestoil.ca/product-cross-reference.php?year=1996&make=TOYOTA&model=TACOMA&engine=2.7L&vin=1
Extract.......
.Engine, 2WD, with filter - 5.4 quarts [1]
Engine, 4WD, with filter - 5.3 quarts [1]
Cooling System, Initial Fill - 9 quarts
Automatic Transmission, A340E Initial Fill - 1.7 quarts
Automatic Transmission, A340F Initial Fill - 2.2 quarts
Automatic Transmission, A43D Initial Fill - 2.6 quarts
4 speed A340F - 10.4 quarts
4 speed A340E - 7.7 quarts
4 speed A43D - 6.9 quarts
Manual Transmission, - 5.3 pints
Differential, With ADRD Front - 2.6 pints
Differential, Without ADRD Front - 2.4 pints
Differential, 2WD Without LSD Rear - 6 pints
Differential, 4WD Extra Long Rear - 4.5 pints
Differential, With LSD Rear - 6.4 pints
Differential, Standard Rear - 6 pints
Transfer Case, - 2.2 pints\'
Sep 13, 2014 | 1996 Toyota Tacoma
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
Oil capacity on a 1991 geo storm
1991 GEO STORM 1.6L 4-cyl Engine Code 5 DOHCCAPACITIES
Engine, with filter.......... 3.2 quarts
Cooling System, W/ MT Initial Fill.......... 7.4 quarts
Cooling System, W/ AT Initial Fill.......... 8.0 quarts
Automatic Transmission, Initial Fill........ 4.3 quarts [1]
Automatic Transmission, Total Fill......... 7.0 quarts
Manual Transmission, ..........4.0 pints[1] With ENG at operating temperature, shift through all gears.
Check fluid level in PARK and add fluid as needed.1991 GEO STORM 1.6L 4-cyl Engine Code 6 SOHC
1992 GEO STORM 1.8L 4-cyl Engine Code 8 DOHCCAPACITIES
Engine, with filter.......... 4.0 quarts
Cooling System, W MT Initial Fill........... 7.4 quarts
Manual Transmission, .......... 4.0 pints[1] With ENG at operating temperature, shift through all gears.
Sep 12, 2012 | 1991 Geo Storm
I have a gmc Yukon Denali xl and needed to know how many quarts of ATF transmission oil do I need to flush my trans
if the transmission fluid is brown or it hasn't been changed then I would flush it
Here is what I have listed, more than likely you have the 4L60E which is 5qts.
CAPACITIES
Engine, with filter..........6.0 quarts[1]
Cooling System, Initial Fill..........17.0 quarts
Cooling System, W/ Rear Heat Initial Fill..........19.0 quarts
Automatic Transmission, 4L80E Initial Fill..........7.7 quarts[2]
Automatic Transmission, 4L85E Initial Fill..........7.7 quarts[2]
Automatic Transmission, 4L60E Initial Fill..........5.0 quarts[2]
4 speed 4L60E..........11.0 quarts
4 speed 4L80E..........14.0 quarts
Dexron VI is the way to go. As for a filter the choice is yours..Hope this helps Tim
May 22, 2011 | 2005 GMC Yukon Denali
Need to know how much transmission fluid to add if empty
Automatic Transmission, E4OD Initial Fill..........6.5 quarts
Automatic Transmission, C6 Initial Fill..........6 quarts
Automatic Transmission, 4R70W Initial Fill..........5 quarts
Automatic Transmission, 4R75W Initial Fill..........5 quarts
4 speed E4OD..........15.7 quarts
4 speed 4R70W..........14 quarts
3 speed C6..........12.1 quarts
4 speed 4R75W..........14 quarts
E 150 5.0L engine
Feb 22, 2011 | 1996 Ford Econoline
How much oil does my 2001 silverado k3500 with 8.1 L gas engine hold?
All TEMPS......5W-30
Engine, with filter..........6.5 quarts [1]
Cooling System, AT Initial Fill..........20.8 quarts
Cooling System, MT Initial Fill..........21.2 quarts
Automatic Transmission, 1000 Initial Fill..........7.4 quarts [2]
Automatic Transmission, 4L80-E Initial Fill..........7.8 quarts
4 speed 4L80-E..........13.6 quarts
5 speed 1000..........12.7 quarts
Manual Transmission, NV4500 (TOPC)..........7.9 pints
Manual Transmission, ZF S6-650..........12.7 pints
Feb 03, 2011 | 2001 Chevrolet Silverado 3500
Transmission filter rplacement how much fluid?
Automatic Transmission, 46RH Initial Fill..........4.1 quarts
Automatic Transmission, 44RE Initial Fill..........4.1 quarts
Automatic Transmission, 42RE Initial Fill..........4.1 quarts
4 speed 44RE..........11 quarts
4 speed 46RH..........14.4 quarts
4 speed 42RE..........11 quarts
Jan 29, 2011 | 1995 Jeep Grand Cherokee
How many quarts of transmission fluid does it hold
You didn't state what size engine you have.
The 2.2 engine----- 6.9 qts.
The 2.3 engine-----7.4 qts.
The 2.4 is 7.4 qts.
The 3.1 is 7.4 qts.
The 3.4 is 6.9 qts.
These are the capacities for refilling after being drained.
Nov 17, 2009 | 2001 Pontiac Grand Am SE
Washer wont initially fill. all other operations
Check the screen on the inlet hose from water fill. If not, it is the timer that you set (it's not functional)
Jul 08, 2009 | Kenmore Washing Machines
Ricoh Aficio 1027 All-In-One Laser Printer Logo
440 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
