Question about Panasonic Viera TH-42PX80U Plasma TV
Panasonic viera doesn't display computer correctly
When I connect my Sony Vaio to my 42" Panasonic Viera 720p plasma via the HDMI input, the screen is not displayed properly. It cuts off about 5% on every side, like it is "zoomed in" too far. I can't figure out how to adjust this. Any help? I tried changing the resolution but edges of the screen are still missing. I'm using Ubuntu.
  • 1 more comment
  • Anonymous Jan 31, 2009
    Same problem!
  • jcaesar Feb 01, 2009
    Me too. I read the manual that came with the tv and under the hdmi section it says that this port is not for computer connection - it actually says that, but doesn't say why. Maybe this is the reason. I hope not. I too have been messing around with the resolution and haven't been able to adjust it.
    Anyone, please help. You'd be saving a man who would be murdered if he had to tell his wife they need a new tv!
  • gcharlie805 Apr 29, 2009
    yeah in the manual it says pc connection via hdmi is not assumed? anyways ive tried going from vga to dvi and from dvi to hdmi and it still doesnt work. i heard that only works with mac? the other thing ive tried is converting from vga to rgb (component) and still nothing. I called a couple of low voltage retailers and they say I need a converter box, which converts the vga (analog signal to rgb digital) the converter box costs around 200 im still waiting on it. I will give you an update as soon as i try it. I also tried svideo to rgb and i do get picture but its black and white with no sound. Next time you buy a tv make sure it comes with a vga input or that atleast the hdmi inpurt is compatible with plug and play for pc/laptop. I do have a 32 in vizio and it has vga input, but i use the hdmi input for my laptop and it works fine.
2 Suggested Answers
  • 4 Answers
SOURCE: panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Posted on Dec 30, 2008
I have had what is fundamentally the same problem. I have a desktop PC that I am plugging in to my Panasonic Viera TX-32LZD80. I am using DVI connection plugged in to HDMI port.
The solution is fairly simple; use the Menu button on the TV remote to get to the Main Menu for the TV and then select Setup which should be the fourth of four options. This will get you to the Setup Menu for the TV for the current channel. Look for the Picture Overscan option, it will very probably be set to On if you have the problem of %5 or so of display being missing on all sides.
Switch Picture Overscan to Off.
This immediately should solve your problem. A note of warning on this is that I suspected this was the problem but when I first looked at the Setup Menu I could not find the Picture Overscan option.
If you are unable to find the Picture Overscan option then trying fiddling with the Aspect settings. You will probably find it set to Auto. Switch it to 16:9 and you should find the Picture Overscan option will be available from the Setup Menu.
Hope it works for you.
Posted on Apr 25, 2009
Whats the best way to install a panasonic viera tc-p50x3 to a yamaha home theater receiver rx-v371 to a panasonic blueray dmpbd75 using dishnet work hddvr set top box
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output
is available , ill be honest with you this is a good job .
Dec 07, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
How much would it cost for screen on a 42 inch plasma screen
tcp42x3.jpg Panasonic Viera TC-P42X3 42 inch Plasma TV with 2 HDMI inputs
Your Cost: $640.79
  • 600 Hz Sub-field Drive: Yes
  • Image viewer: Yes (AVCHD/MPEG2/JPEG/MP3 playback)
  • Energy Star qualified: Yes
  • HDMI: 2
  • USB: 2
Apr 27, 2011 | Televison & Video
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Dec 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
How do I set up my Panasonic Viera to connect via HDMI to my Direct TV receiver?
Cliff, it al depends on what kind of DIRECT TV receiver you have, if it has an HDMI port on the back of the receiver then all you have to do is plug it in and change the input on your TV to HDMI
Enjoy thats a great TV
Dec 03, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Audio drop outs when using HDMI connection on new Viera
The way I solved it was to go into advanced settings and change the audio input connected to the hdmi port to component. I had to run an audio cable from the cable box into the TV but since I did this we haven't had the problem.
Jul 13, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Mar 03, 2009 | Televison & Video
Dec 29, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Viera TH-42PX80U Plasma TV Logo
295 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
