Question about Samsung V25 XVC 2800 Notebook
Samsung p28 laptop will not boot up
9 times out of 10 on boot up i just get a black screen. every now and then it boots up and offers me options prior to freezing up. such as refer to earlier config and safe mode on a black background but does not let me acess these menus. Or it boots into windows and then goes to a black screen.
  • andy fox Jun 22, 2007
    on the one occasion the restore CD launched it froze after 2 minutes.
  • Anonymous Mar 25, 2014
    My pc goes through boot up and shows some message pertaining to my ntfs then it opens windows and freezes. it later goes to a black screen
    New Friend:
I had a few different issues with windows 10 freezing. Updated my bios and that fixed all 3 problems
Posted on Sep 23, 2015
My laptop samsung p28 keeps swiching off after about 20 minuets the fan has been checed so has the processor and heat sink and they are fine and its doin my brain in.any one help.
Posted on Nov 17, 2008
If you have one of the following Motherboards
OSCAR BA92-03113A or OSCAR BA92-03114A
then forget ist. No way to fix it because the whole
production series has a severe layer problem near
the CPU.
Posted on Apr 23, 2008
Recovery CD will not help. There is a motherboard failure.
Posted on Jan 24, 2008
    Genius:
  • 2,985 Answers
Do you not have a Reoery disk with this machine?
Posted on Jun 22, 2007
  • john ash
    john ash Jun 22, 2007
    Should read Recovery Disk
SOURCE:
Need help - black screen on Samsung 700A3D
Looks like the boot manager file could be damaged or a driver is missing. Use your windows disk to boot from and choose the repair option.
Aug 31, 2016 | Samsung Computers & Internet
The boot configuration data for my pc is missing or contains errors
Unless you took the time to create your own boot/recovery media (CDs) when you first got the computer, your only option would be to get on another computer and check for the availability of them on the vendor's website. (A real pain due to the many different models and configurations)
Have you tried a boot-up in *Safe Mode*? This will only be possible if offered as a failed, boot-up option screen, though. Sometime, if the boot files that are missing or have error are not too damaged they can be rebuilt when booting up in Safe Mode.
It might be possible to boot up into the BIOS - power it on and then repeatedly type the correct function key. (Check your manual for the right one.) Some BIOS configurations have an option to run Checkdisk - a DOS program which can sometimes rebuild boot files.
Apr 02, 2015 | Acer Aspire V3-571 15.6-Inch Laptop -...
Acer aspire 6930 6941 won't boot
won't get the check disc option until it boots up and from your description is is a hard drive problem
take it in for a proper diagnosis
Apr 25, 2017 | Computers & Internet
How to giving boot with different ways to acer travelmate 2423 laptop
1) You can set your boot options in your bios, watch as you laptop boots, you should see something like "Hit F2 to enter setup". Hit F2, select boot options then choose to boot from CD, HDD or external drive. Take care because you don't want to mess up your Bios. So read the screen carefully before changing anything. When you're happy, select save and exit then reboot, you should then boot from the device of choice in the order of choice.
2) Windows boot options, windows has several options for booting from, including safe mode. To do this, hit F8 several times while the laptop is booting, you should come to a screen with the several options on offer.
Feb 12, 2012 | Acer Computers & Internet
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
My laptop is at a black screen that says windows boot manager......under that heading it says that windows failed to start due to a hardware or software change....how do i fix this?
does it offer you the option of pressing F1 to continue?
try that if you can, if its not there, it means the Windows Master Boot Record is broken and needs to be rebuilt.
Windows itself is likely to be ok.
If you have a Windows disk (if you are running Vista, the vista cd, and likewise with Xp, using the XP CD) - start the computer with the CD in the drive, and press any key to boot from CD when offered.
If it doesnt offer this, you need to change your boot order in the BIOS.
the BIOS is the screen right before the screen where you are getting that error.
it is the screen that counts up the RAM, around the Time the PC beeps jsut after turning it on.
there should be a prompt on that screen to get into Setup or BIOS by pressing a key. on Dell machines, it is F12, on IBM is often F2, and on my PC (an ASUS) it is DEL key you press to get into the BIOS.
once in there, you need to find the boot order sequence entry.
ensure the order has CD Rom before the primary hard disk.
save that and boot the PC, hopefully the CD will boot this time . when the CD starts up, you get an option to repair Windows, Install Windows, or enter the Recovery Console.
Press the key (i think it is ' R ') to Select Recovery Console.
once it loads up the DOS screen and is waiting for your input, just ype
FIXMBR
this does assume your Windows installation is sitting on your c:\ partition. refer to the following site if your windows install is NOT on c:\
Press Y to confirm and reboot the PC.
it should now load your copy of Windows.
Microsoft site has an article on the Recovery Console, so please refer to this for more information.
http://support.microsoft.com/kb/314058
Jun 24, 2010 | Computers & Internet
P28 laptop blue screen it starts up with the windows logo then shuts down
hello
i have problem my laptop no work and i search laptop P28. i want buy model laptop P28. i need in changer block mainboard for loptop P28
If you can me help. please help me. i buy old laptop Samsung P28
hope you help me
Thank you
my e-mail: [email protected]
Sep 24, 2009 | Samsung V25 XVC 2800 Notebook
Have windows vista business 32 SP1 its like the szstem can not find the users profile and enter in a black desktop giving me errors like: host process for windows Services stopped working and was close. A...
I would just run a full reinstall if I were you but try this first:
Boot and insert Vista install or recovery DVD (any Vista disc will do for this)
Reboot and hopefully it will offer the option to boot from the DVD. Take this option and follow it through until you are offered the option to install Vista or repair your computer. Just follow things though from there and it MAY repair the problem.
If it does not offer you the initial boot option then look on the initial boot screen for the boot options key - probably F11 or F12 - and press that during initial boot to obtain the boot options screen
After that its a full reinstall by the sounds of it - save your data to a stick or DVD first though
Dec 21, 2008 | Sony VAIO VGN-SZ470N/C PC Notebook
Start-up shows "Launch Start-up recovery" but am unable to proceed
This is Vista you are running and there are a couple of options. I'll go for the easy one first
Reboot and hopefully it will offer the option to boot from the DVD. Take this option and follow it through until you are offered the option to install Vista or repair your computer. Just follow things though from there and it MAY repair the boot problem.
Dec 14, 2008 | Acer Computers & Internet
Laptop shows lock-9 sign when powering up, then cannot get beyond
hit the number lock key - don't try to hit the "function (fn)" key + number lock. Just the numberlock key SOLO
Dec 11, 2008 | Dell Latitude D600 Notebook
Samsung V25 XVC 2800 Notebook Logo
1,379 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
